Normal Topic I have a new problem now (Read 1627 times)
PDM.
Senior Member
Dec 8th, 2010 at 4:58pm
Stoyo, me again now i have a new problem.
Sorry for all large list of questions but i need stay secure all what i need work, before order a licence.
I continue working on the example FORMEDITOR
I make some simple changes to the formeditor, but cant make the form use all screen:
Here the changes:
<Window x:Class="FormEditor.Window1"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:d="http://mindfusion.eu/diagramming/wpf"
xmlns:f="clr-namespace:System.Windows.Forms;assembly=System.Windows.Forms"
xmlns:wfi="clr-namespace:System.Windows.Forms.Integration;assembly=WindowsForms
Integration"
Title="MindFusion.Diagramming Sample: Form Editor"
Width="703" Height="570"
Loaded="Window_Loaded" Name="window" Icon="/FormEditor;component/App.ico" AllowsTransparency="True" WindowStyle="None" Background="Transparent" WindowState="Maximized" >
<Grid>
<d:Diagram Name="form" BackBrush="Black"
SelectAfterCreate="False"
NodeCreated="form_NodeCreated"
NodeActivated="form_NodeActivated"
InitializeNode="form_InitializeNode"
NodeSelecting="form_NodeSelecting"
</d:Diagram>
<ListBox Height="100" HorizontalAlignment="Right"
Margin="0,13,101,0" Name="palette" VerticalAlignment="Top" Width="120"
SelectionChanged="palette_SelectionChanged" >
<ListBoxItem>Button</ListBoxItem>
<ListBoxItem>TextBox</ListBoxItem>
<ListBoxItem>Label</ListBoxItem>
</ListBox>
<Button Height="23" HorizontalAlignment="Right" Margin="0,13,11,0"
Name="btnSave" VerticalAlignment="Top" Width="75" Click="btnSave_Click">Save</Button>
<Button Height="23" HorizontalAlignment="Right" Margin="0,52,11,0"
Name="btnLoad" VerticalAlignment="Top" Width="75" Click="btnLoad_Click">Load</Button>
<wfi:WindowsFormsHost Margin="0,124,11,13" HorizontalAlignment="Right" Width="210" Background="Black">
<f:PropertyGrid Height="23" Margin="0,82,11,0" x:Name="propGrid" />
</wfi:WindowsFormsHost>
</Grid>
</Window>
New CODE:
private void Window_Loaded(object sender, RoutedEventArgs e)
WIDTH = SystemInformation.PrimaryMonitorSize.Width;
HEIGHT = SystemInformation.PrimaryMonitorSize.Height;
form.Width = WIDTH;
form.Height = HEIGHT;
You can see the form never cover all the screen.
Why?
is like form can be more bigger.
Is really strange.
Re: I have a new problem now
Reply #1 - Dec 8th, 2010 at 7:04pm
SystemInformation.PrimaryMonitorSize returns size in physical pixels. Since you are setting the window state to maximized, you can get the screen size in WPF points from the window's ActualWidth and ActualHeight:
var WIDTH = this.ActualWidth;
var HEIGHT = this.ActualHeight;
form.MeasureUnit = GraphicsUnit.WpfPoint;
form.Bounds = new Rect(0, 0, WIDTH, HEIGHT);
PDM.
Senior Member
Reply #2 - Dec 8th, 2010 at 9:34pm
Thnakyou that fixed the resize thing.
I continue checking now  : )
