Normal Topic Aligning nodes (Read 1660 times)
Naganathan
Aligning nodes
Dec 9th, 2010 at 6:56am
We want to align the diagram nodes based on a primary selection.Currently we are using Diagram.Selection.Items.FirstOrDefault() as the primary item and aligning the other nodes with reference to this primary node.But the problem is we want the first selected node to be considered as primary.But if we take the first item from the Diagram.Selection.Items,its changing randomly.Means we are not able to get the primary selection.Is that any way to do this?
Thanks,.
Naganathan NS
Re: Aligning nodes
Reply #1 - Dec 9th, 2010 at 8:20am
Diagram.ActiveItem designates the primary selected item, and you can customize ActiveItemHandlesStyle to make it stand out among the others.
