Normal Topic issue in Node copy (Read 1578 times)
madhan1
FOLLOW NO ONE BUT LEARN
FROM EVERY ONE ..
issue in Node copy
Dec 13th, 2010 at 11:42am
dear all,
when i am copy and paste a telephony node in a new form then i can paste only the diagram but not the properties  of that node.kindly help me (sorry iam good in english.)
if you want something then go and grab it
Re: issue in Node copy
Reply #1 - Dec 13th, 2010 at 12:50pm
If that's a custom node class, you must override the SaveTo and LoadFrom methods to serialize the property values. The IconNodes sample project shows how to do that.
madhan1
FROM EVERY ONE ..
Reply #2 - Dec 14th, 2010 at 3:47pm
thanks i will try and tell you
