Normal Topic Establishing ZoomLimits using ZoomToRect (Read 1864 times)
kaykay15
Dec 14th, 2010 at 3:48pm
Hello Stoyon,
It has been a long long time i've posted in this fourm.... The Mindfusion diagramming component was a perfect match for our requirement.. Our applicaiton has just crossed the beta stage and is live now, you can view it now @ http://www.ravencloud.com
Cheers Mindfusion team.
The thing i came back here is; we need to set the zoom limits for the diagram. We are using the diagram.ZoomToRect() method for zooming, Currently if we allow the end user to zoom with out limit; there is a performance issue as the application is getting slowed down.
So now we need to limit the zooming level of the diagram.
i have tried to reset the zoomlimit to 200 if the zoomlimit is greater than 200 after ZoomToRect() method.
It is limiting the zoomlevel but not centering the selected region; is there any way to center the selected region and limit the zoom factor of the diagram?
-KayKay
Thanks,&&-KayKay
Re: Establishing ZoomLimits using ZoomToRect
Reply #1 - Dec 14th, 2010 at 4:35pm
Congratulations 8)
You could call ZoomToRect again for easier centering. It should look something like this:
diagram.ZoomToRect(rect);
if (diagram.ZoomFactor > 200)
	double ratio = diagram.ZoomFactor / 200;
	double w = rect.Width * ratio;
	double h = rect.Height * ratio;
	double dx = w - rect.Width;
	double dy = h - rect.Height;
	rect.X -= dx / 2;
	rect.Y -= dy / 2;
	rect.Width = w;
	rect.Height = h;
kaykay15
Reply #2 - Dec 16th, 2010 at 7:55am
Works like a charm!
Stoyon... You Rock...
Thanks,&&-KayKay
