Normal Topic Some questions about form editor sample (Read 2549 times)
PDM.
Senior Member
Dec 23rd, 2010 at 9:31pm
Hi Stoyo, i continue checking the FORM EDITOR sample, and have a new siple question for create node, you have to drag over the form.
I not like a lot that way due some times you drag, node or is to llite or to big.
Is possibls change that  for make node is created just clicking over the form?
I think for me is better click and node is created at defalt size and seting in xaml SelectAfterCreate="True" select after is created.
The question is how, make node is crated with just single and siple clcik and not dragging?
Best regards.
« Last Edit: Dec 25th, 2010 at 8:34am by PDM. »
Re: Some questions about form editor sample
Reply #1 - Dec 27th, 2010 at 9:55am
Hi Pablo,
You can do that by handling diagram.Clicked:
private void form_Clicked(object sender, DiagramEventArgs e)
	var constructor = form.DefaultControlType.GetConstructor(System.Type.EmptyTypes);
	var instance = constructor.Invoke(null) as UIElement;
	var node = new DiagramNodeAdapter(instance);
	var bounds = new Rect(e.MousePosition, new Size(128, 128));
	bounds.Offset(-bounds.Width / 2, -bounds.Height / 2);
	node.Bounds = bounds;
	form.Items.Add(node);
	node.Selected = true;
PDM.
Senior Member
Reply #2 - Mar 21st, 2011 at 7:00am
Hello
This work perfect, but how can disable NODE creation when drag and only allo creation of node when node is clicked?
« Last Edit: Mar 21st, 2011 at 8:11am by PDM. »
Reply #3 - Mar 21st, 2011 at 8:43am
Hi Pablo,
Set Behavior = Modify to only allow moving and resizing nodes with the mouse. Then the only way for the user to create a new node will be through the Clicked handler.
