Normal Topic Selecting Items within a group (Read 1812 times)
samuelt
Jan 4th, 2011 at 12:14am
I searched this forum and found a code to create a group.
private void CreateGroup(DiagramNode node, DiagramNodeCollection children)
Rect r = Rect.Empty;
foreach (DiagramNode child in children)
Rect cb = child.Bounds;
r = r.IsEmpty ? cb : Rect.Union(r, cb);
double margin = 5;
r.Inflate(margin, margin);
node.Bounds = r;
child.AttachTo(node, AttachToNode.TopLeft);
However, I'm trying to find a way to select the item inside of the group to resize, move and link to/from.
I need to do this a couple of nested groups down as well. What do you think is the right approach?
Thanks.
Re: Selecting Items within a group
Reply #1 - Jan 4th, 2011 at 10:28am
I can't see any problem selecting attached nodes while using default settings and having the master node at lower Z index. Please check if your child nodes are not Locked, and perhaps try different values for the HitTestPriority and SortGroupsByZ properties.
samuelt
Reply #2 - Jan 5th, 2011 at 4:13pm
Thanks.
