Normal Topic Changing node click/drag behaviour (Read 2966 times)
matt.s
Jan 7th, 2011 at 3:33pm
Currently we have the diagram configured so that;
1) if you click and drag the middle of a node the node will be moved
2) if you click and drag the edge of a node an arrow is created
Our users are telling us that they are finding it hard to discover how to create arrows, and also that they create arrows by mistake when instead they were intending to move a node.
Is it possible to;
1) Change it so that if the user clicks and drags anywhere in a node the node is moved
2) Display a small 'indicator' arrow at the bottom of a node, which when clicked and dragged creates a new arrow.
Matt
Re: Changing node click/drag behaviour
Reply #1 - Jan 7th, 2011 at 3:56pm
It is possible. For example:
diagram.ShapeHandlesStyle = HandlesStyle.MoveOnly;
diagram.ModificationStart = ModificationStart.AutoHandles;
diagram.CustomBehavior = new MyBehavior(diagram);
where MyBehavior.StartDraw looks like this:
public override InteractionState StartDraw(Point point)
	var node = Diagram.GetNodeAt(point);
	if (node != null)
		var indicatorLocation = node.Bounds.BottomRight;
		if (Utilities.Distance(indicatorLocation, point) < 5)
			var link = CreateLink();
			link.Origin = node;
			return new InteractionState(link, -1, Action.Create);
	return base.StartDraw(point);
Also override the behavior.SetCursor method so that the control shows a different mouse pointer when over the indicator.
As for drawing the arrow indicator - if you are using ShapeNodes and their Image property is free for this, set it to the indicator image along with ImageAlign = BottomRight. Otherwise you can custom-draw it by handling DrawNode, or add it to the node template if using TemplatedNodes.
matt.s
Reply #2 - Jan 7th, 2011 at 5:15pm
Hi Stoyan,
Thanks for this - however if I click anywhere around the edge of the node and drag it will try and create a link - is there anyway of preventing this from happening?
matt.s
Reply #3 - Jan 7th, 2011 at 5:35pm
Actually forget that, by messing round with my adjustment handles I can see why this is happening.
