Normal Topic Need To Style Container on DrawContainer Behaviour (Read 1979 times)
kaykay15
Jan 18th, 2011 at 12:40pm
Hello Stoyon,
We have implemented the ZoomToRectangle Behaviour in Silverlight, now we are trying the same in WPF.
In Silverlight to draw the selection rectangle we have set the behaviour of the diagram to Behaviours.DrawContainer, this works as it draws a semi-transparent rectangle.
But now when we implement the same in WPF, it draws a container having a title named "Container" and with a solid white background. how do i override this behaviour to make the selection rectangle as semi transparent rectangle.
-KayKay
Thanks,&&-KayKay
Re: Need To Style Container on DrawContainer Behav
Reply #1 - Jan 18th, 2011 at 12:59pm
Try setting the container's CaptionHeight to 0 and Brush to some translucent color in response to the InitializeNode event.
kaykay15
Reply #2 - Jan 18th, 2011 at 2:43pm
Smiley works...
Thanks a lot once again!!!!!!!!!!!!
Thanks,&&-KayKay
