Normal Topic print viewer (Read 2860 times)
thierry
print viewer
Jan 24th, 2011 at 5:09pm
I would like to allow the application users to print their planning, so I used the function calendar.PrintPreview and it works well. My problem is that the presentation of the report viewer has not the same "look" as the rest of the application. Could I customize the buttons of your report viewer ? If not could I open the impression in Microsoft Report viewer ?
Best Regards
Thierry
Re: print viewer
Reply #1 - Jan 25th, 2011 at 7:41am
Do you want to change only the images of the toolbar buttons in the Print Preview form? In this case we can implement a property which enables you to do so. Otherwise we can enable printing on external PrintDocument objects and then you can display those PrintDocument objects in custom containers, such as PrintPreviewControl embedded on a custom form.
thierry
Re: print viewer
Reply #2 - Feb 10th, 2011 at 1:31pm
Could you please enable printing on external PrintDocument objects ?
Best Regards,
Thierry
Re: print viewer
Reply #3 - Feb 10th, 2011 at 2:51pm
Try this version:
https://mindfusion.eu/_pln_trial/MindFusion.Scheduling.5.1.2.zip
The Print and PrintPreview methods now have overloads which accept external PrintDocument as a target of the print or preview operation.
Let me know if this helps.
