Normal Topic Anchor points (Read 2240 times)
frankinstien
Anchor points
Feb 3rd, 2011 at 5:27pm
I'm trying to add anchor points to shape nodes and after that is done I try to connect links. Well the anchor points from each node don't seem to work when I hover over the anchor I want to connect to. It connects to the first anchor of the node. Is there a way to prevent this so I can connect any anchor point to any other anchor?
I'm using version 5.5
Frank
Re: Anchor points
Reply #1 - Feb 3rd, 2011 at 5:59pm
Have you set the AllowIncoming and AllowOutgoing properties to true for all anchor points?
frankinstien
Re: Anchor points
Reply #2 - Feb 3rd, 2011 at 6:31pm
I just tried that; what happens is if the same object is used to connect to a different anchor the original anchor is what it ends up connecting to.
If I move the object about the links reconnect to anchors that are closest to the object that is being moved.
I need the links between anchors to be perminate or static once they've been connected.
Re: Anchor points
Reply #3 - Feb 3rd, 2011 at 6:50pm
I think the Dynamic property does that. Is it enabled for your links?
frankinstien
Re: Anchor points
Reply #4 - Feb 3rd, 2011 at 9:19pm
that did it, thanks.
