Normal Topic ShapeNode Id use (Read 2881 times)
felix.kaelin
ShapeNode Id use
Feb 9th, 2011 at 10:48am
Hi people,
I try to identify the ShapeNode's on a diagramm by the id on an event like this:
[code]
private void diaPool_LinkCreated(object sender, MindFusion.Diagramming.LinkEventArgs e)
if (e.Link != null)
if ((e.Link.Destination != null) && (e.Link.Origin != null))
Console.WriteLine(e.Link.Origin.Id);
[/code]
But the id is null.
Must I set the id after create the shapenode or is it setted by the diagram?
Gr33z3
Felix
Re: ShapeNode Id use
Reply #1 - Feb 9th, 2011 at 10:59am
Hi Felix,
The Id property is not set automatically, it is used for storing custom data just as Tag and you must set it yourself. You can assign to it integer values using the method shown in the post below, or perhaps Guid instances or string values.
http://mindfusion.eu/Forum/YaBB.pl?board=wpfdg_disc;action=display;num=129291942...
felix.kaelin
Reply #2 - Feb 16th, 2011 at 3:57pm
Hi Stoyan,
yes for the moment it has worked, but now I've got a problem more whit the Id.
When i save the whole diagram to a String and load it back like this:
string test = this.diaPool.SaveToString();
this.diaPool.LoadFromString(test);
I lose the value in the Id.
So now the question:
Have you implemented some function that I can override and so save the value in the Id or is that implemented allready and I miss some configuration?
Gr33z3
Felix
Reply #3 - Feb 16th, 2011 at 4:06pm
Hi Felix,
If you are using simple types such as string or integer the values should be saved automatically. If you are using your custom type as id, make it [Serializable] and it should be serialized automatically too. If you save to XML format, handle the SerializeTag and DeserializeTag events to serialize the id values as custom XML attributes or elements.
felix.kaelin
Reply #4 - Feb 17th, 2011 at 10:02am
Hi Stoyan,
very big thanks. That was the problem I need to fix, serialize the class I've created for the Id  Cheesy
So now it works very fine.
Gr33z3
Felix
