Normal Topic Loading a big range of Resources (Read 2481 times)
thierry
Feb 10th, 2011 at 2:01pm
I load in the planner a big quantity of resources (aproximately 1000). On this big range of resources the Scheduler is very slow.
To load them, First I load the resources in the calendar.Schedule.Resources collections, then, I load my appointment in calendar1.Schedule.Items.
Finally (and it's the slowest section) I read all the calendar.Schedule.Resources collection to add the objects in calendar.Resources like this :
calendar1.Resources.Add(calendar1.Schedule.Resources[i]);
Do you know another way to load datas faster ?
To solve the time loading problem, I have tried to load the 30 First resources normally and the 970 next with an asynchronous thread. Like this :
  void AddResources(int i) {
   if (!calendar1.InvokeRequired) {
    if (i % 20 == 0) {
     calendar1.ResumeLayout();
     calendar1.SuspendLayout();
   else {
    calendar1.Invoke(new AddResourcesDelegate(AddResources), new object[] { i });
This Solution gives a best video result than the first one (the screen remains white during the 1000 loading datas in the first case) but, the scheduler keep a big rate of system resources, and even if I call just a messagebox the called form appears just after the 1000 datas are completely loaded.
How could I solve this problem ?
Best Regards,
Thierry
Re: Loading a big range of Resources
Reply #1 - Feb 10th, 2011 at 2:48pm
Wrap the initialization code in a BeginInit/EndInit block, as illustrated by the following sample:
calendar1.BeginInit();
for (int i = 0; i < 1000; i++)
	Resource r = new Resource();
	r.Name = i.ToString();
	calendar1.Resources.Add(r);
	calendar1.Schedule.Resources.Add(r);
calendar1.EndInit();
The loading will be much faster, but the overall user experience with a calendar displaying thousand resources will be cumbersome.
Let me know if this helps.
thierry
Reply #2 - Feb 13th, 2011 at 11:50am
Thanks, exactly what I want.
Best Regards,
Thierry
