Normal Topic performance problem in LayeredLayout (Read 1214 times)
Tor
Feb 10th, 2011 at 6:20pm
In our application we have attached svgnodes to shapenodes in order to get visually appealing anchor points. This has worked out well except when we do autolayout.
We have experimented a bit with the LayeredLayout. The first problem was that the anchorpoints were included in the autolayout routine and got separated from their parent. This was solved by setting their IgnoreLayout property to True.  This had the problem that the shapenode with its anchorpoints were not icluded in the layout.
The solution seemed to be to include the ancorPoints in the layout again and instead set _layout.KeepGroupLayout = true. Everything works fine for small test-samples but setting KeepGroupLayout = true has a serious performance penalty when starting AutoLayout on big samples. Has anyone experienced the same behaviour?
Re: performance problem in LayeredLayout
Reply #1 - Feb 11th, 2011 at 11:17am
I suppose everything will be slower when you multiply the number of nodes just to display prettier anchor points; e.g. hit-testing, routing, layout will have worse performance. You could set the anchor points' style to Custom and call SvgContent.Draw from the DrawAnchorPoint handler instead of adding SvgNodes.
