Normal Topic Diagramming for Windows Forms, V5.6 (Read 1780 times)
Feb 11th, 2011 at 12:36pm
We have released version 5.6 of FlowChart.NET. It contains the following new features:
Components
A new UI component system is now available for use in diagram nodes. The components represent graphical widgets similar to controls, which can be arranged in hierarchies and added to the diagram through instances of the new CompositeNode class. Flowchart.NET comes with various built-in components, such as layout panels, edit and button widgets. It is also possible to create custom component classes. Component hierarchies can be defined and loaded from XML, very much like WPF/XAML. A new tutorial section has been added to the help file describing various component features in a step-by-step examples.
~ SvgNodes now support SVG text and marker elements.
~ NodePointed and LinkPointed events are raised when the mouse hovers over a diagram item.
~ The Ruler.InchDivisions property specifies how many minor divisions to display when Unit is set to Inch.
~ Derived item types can control the position of attached nodes by overriding UpdateGroup.
