Normal Topic Can I user AjaxManagerProxy InteractivityExtender (Read 2222 times)
Hamdy Ghanem
Feb 14th, 2011 at 6:06am
My situation as follow
I am working in a site that has a default page
and creating a widget (ascx control ) that has a diagram
I have already a scrit manager in the default.aspx page , so I can not add another one in the control page  that has the diagram
I tried to use AjaxManagerProxy but the digram is not working it is not display any thing and not displaying error as well
Re: Can I user AjaxManagerProxy InteractivityExten
Reply #1 - Feb 14th, 2011 at 8:00am
You don't need a ScriptManager in the UserControl; in our test site the extender worked fine with the ScriptManager from the containing page. Do you keep the files for your user control in a separate folder? Perhaps you should also move ImageGen.aspx there in such case.
Hamdy Ghanem
Reply #2 - Feb 14th, 2011 at 10:39am
Where is the page  ImageGen.aspx
and couild I add querystring while the diagram calling it
check this please
http://mindfusion.eu/Forum/YaBB.pl?board=netdg_disc;action=display;num=129767498...
Hamdy Ghanem
Reply #3 - Feb 14th, 2011 at 10:41am
yes the user control in another folder
how I move imageGen.aspx
Reply #4 - Feb 14th, 2011 at 11:51am
Ok, our developer tried this with a subfolder too. It worked without any other changes after we only moved the .ascx file to subfolder, as long as imagegen.aspx is in the site's root folder. When we also moved imagegen.aspx to the subfolder, we had to update the ImageGenLocation property for the user control to render correctly. So I suppose the diagram should appear if you set up imagegen.aspx in either of these two ways.
