Normal Topic Text Wrapping in not working properly (Read 3843 times)
Anshul
Senior Member
Feb 18th, 2011 at 11:07am
Hi Stoyan,
For ShapeNode's text in our application we want following behavior.
1. Text should come within its text area.
2. If text is larger and continuous (don't have spaces in between the words) than text should wrapped to the second line.
3. If text is larger enough and still not coming in two lines than it should not go to the third line, instead it should trimmed.
Let know how we can achieve TextWrapping.None with TextWrapping.CharacterEllipse?
Anshul
Re: Text Wrapping in not working properly
Reply #1 - Feb 21st, 2011 at 7:06am
This wraps continuous text and trims the last line:
shape.Text = "test123412341234";
shape.TextWrapping = TextWrapping.Wrap;
shape.PolygonalTextLayout = true;
If you don't want to see a third line of text, you must set node.Bounds to a height that fits just two lines.
Anshul
Senior Member
Reply #2 - Feb 21st, 2011 at 8:59am
Hi Stoyan,
It has partially resolved the issue, if text is not properly fitting in two lines than text should get trimmed.
Text area height is not allowing text in third line but i want text trimmed in second line if it is larger for two lines.
How text trimming can be achieved along with the previous solution?
Anshul
Reply #3 - Feb 21st, 2011 at 12:37pm
What's wrong with trimming in the previous solution? Does your text stick out of the node?
Anshul
Senior Member
Reply #4 - Feb 21st, 2011 at 12:49pm
Not out of the node instead it is clipping from the node border.
I want text should not clip, it should trimmed so that user can easily identify that there are some more text.
Anshul
Reply #5 - Feb 21st, 2011 at 1:11pm
If by trimming you mean displaying ellipsis, use these settings:
shape.TextTrimming = TextTrimming.CharacterEllipsis;
shape.EnableStyledText = true;
