Normal Topic Relation Intermediate Shapes (Read 4639 times)
TyreeC
Feb 23rd, 2011 at 10:21am
Hi, I am having a strange issue when using the DiagramLink.IntermediateShape.
I have two nodes on the view connected via a DiagramLink with the IntermediateShape set to ArrowHead.PointerArrow.
Everything is fine and the arrow points to the correct node.  However, when I move one of the nodes, the arrow flips directions until the node is released again.
I have placed breakpoints everywhere I can think of, but the flip seems to happen before the events such as selectionMoving, nodeModifying and the event linkModifying is never raised.
Can anyone help in explaing how to to stop the arrow flipping during the node movement?
Many thanks for any pointers.
Re: Relation Intermediate Shapes
Reply #1 - Feb 23rd, 2011 at 10:48am
Hi, What version of the control are you using and could you post the link property values here?
TyreeC
Reply #2 - Feb 23rd, 2011 at 12:01pm
Hi, when I look at the details for the MindFusion.Common.dll it says the Product Version is 1.0.2608.20825
When the relation is created we setup the following:
arrow.AutoRoute = false;
arrow.BaseShape = ArrowHead.None;
arrow.HeadShape = ArrowHead.None;
arrow.Brush = new MindFusion.Drawing.SolidBrush(lineColor);
arrow.Pen.Color = Color.Blue;
arrow.Pen.Width = 0.6f;
arrow.IntermediateShape = ArrowHead.PointerArrow;
arrow.IntermediateShapeSize = 2;
arrow.ToolTip = "";
arrow.ControlPoints[0] = new PointF((float)(p1.X + dx), (float)(p1.Y + dy));
arrow.ControlPoints[1] = new PointF((float)(p2.X + dx), (float)(p2.Y + dy));
Hope this is the information you requested, if not please let me know.
Reply #3 - Feb 23rd, 2011 at 12:44pm
Are you sure p1 is located at the origin node and p2 at the destination node?
TyreeC
Reply #4 - Feb 23rd, 2011 at 12:57pm
Looking at the code, yes that seems to be true. The above code is only called once at creation, and the arrow is pointing in the correct direction, it is only while moving one of the nodes the arrow flips over.
Reply #5 - Feb 23rd, 2011 at 1:22pm
If you set HeadShape to a value different from None, what does happen with it once you start moving the node?
TyreeC
Reply #6 - Feb 23rd, 2011 at 2:23pm
Ah-ha, The head arrow appeared on the 'wrong' end.  Further investigation led me to a specific code path that created the initial arrow backwards even though the source and destinations were correct.
Thank you for the prompts, bug fixing others code can be frustrating  Smiley
Reply #7 - Feb 23rd, 2011 at 2:35pm
Always a pleasure Wink
