Normal Topic blocks folding nodes. (Read 2669 times)
gamjaradio
Feb 24th, 2011 at 1:54am
I'm using a IconNode.
and One thing I want is , whenever drawing the Node , it have not to be folded.
Is there method solving it?
Re: blocks folding nodes.
Reply #1 - Feb 24th, 2011 at 11:57am
What do you mean by folded IconNode?
gamjaradio
Reply #2 - Feb 24th, 2011 at 1:12pm
it means ,
I draw a Node at the Point of x=10 , y=10.
Then event if I draw another at x=10 , y=10 ,
that thing has to be relocated x=20 , y=10 automatically cause of blocking folding each other
Reply #3 - Feb 24th, 2011 at 2:54pm
Call this from the NodeCreated handler:
Rectangle2D rect1 = e.getNode().getBounds();
ArrayList<DiagramNode> nodesAtSameX = new ArrayList<DiagramNode>();
for (DiagramNode node : diagram.getNodes())
	if (node == e.getNode())
		continue;
	Rectangle2D.Float rect2 = node.getBounds();
	if (rect2.getMinX() > rect1.getMaxX() ||
		rect1.getMinX() > rect2.getMaxX())
		continue;
	nodesAtSameX.add(node);
boolean intersects = false;
do
	intersects = false;
	for (DiagramNode node : nodesAtSameX)
		if (DiagramNode.nodesIntersect(node, e.getNode()))
			e.getNode().moveTo(
				e.getNode().getBounds().x,
				(float)node.getBounds().getMaxY() + 5);
			intersects = true;
			break;
while (intersects);
