Normal Topic About Zorder (Read 5237 times)
PDM.
Senior Member
About Zorder
Feb 24th, 2011 at 2:09pm
I wnat change z order of my custom nodes.
I use this for send to back:
form.ActiveItem.ZBottom();
form.UpdateLayout();
And this code for send to front:
form.ActiveItem.ZTop();
This work abslutly in erratic way.
Example i create a big squaqre node, and the put inside another more littel suqre inside
I select little node, and run   form.ActiveItem.ZBottom();
The little node over the big node dont go to back, the only way to do that is select the big node and send to front.
This no have logic
What im doing wrong?
Re: About Zorder
Reply #1 - Feb 24th, 2011 at 2:31pm
By default selected nodes are drawn on top of Z order. Try setting diagram.SelectionOnTop = false.
PDM.
Senior Member
Re: About Zorder
Reply #2 - Feb 24th, 2011 at 2:59pm
private void form_NodeActivated(object sender, NodeEventArgs e)
form.SelectionOnTop = false;
This not work, same result.
I create custom node is a square, then put a a second node square inside.
I select the little suqare and try send back, that not work, but if i select the big square and select send to front, work, now little suqare is hiiden by big suqare node....
But now i want send that big suare node, to back again and not work!
If want i uplaod and example tellme, this is a bug?
Can you test and confirm.
Rememebr im working with custom nodes, not with shapenodes provided by mindfusion component.
Anyway i tested this with simple shapes and same happen, i think is a bug or a conceptual error of how z order should work.
Or some mistake form me, but like you see in code aparently this time im doing in correct way : )
Re: About Zorder
Reply #3 - Feb 24th, 2011 at 3:18pm
Are you sure your form_NodeActivated method ever runs? Set SelectionOnTop in the diagram's Xaml code, it's a global property for the diagram and you should not have a reason to change it.
private void OnNodeClicked(object sender, NodeEventArgs e)
	if (e.MouseButton == MouseButton.Right)
		e.Node.ZTop();
	else
		e.Node.ZBottom();
With SelectionOnTop set to false I handled the NodeClicked event as above, and couldn't see any problems with this after drawing several overlapping nodes and clicking with different mouse buttons to send nodes back and forth in the Z order.
PDM.
Senior Member
Re: About Zorder
Reply #4 - Feb 24th, 2011 at 4:39pm
Like always you have reason my mistake again!
Fixed, thank you , anyway new question born of all this.
If i selected with control more of one node, and i try change zorder of all that nodes at same time, not work.
Baiscally is due i working with  Activeitem, example
Exist some method to work with SelectedItems ?
I see same problem whe work with keyboard arrows up , , left down and right and try move multile selected items with keys. etc etc
Best regards.
Re: About Zorder
Reply #5 - Feb 24th, 2011 at 5:18pm
Iterate over diagram.Selection.Items:
foreach (DiagramItem item in diagram.Selection.Items)
     item.ZBottom();
PDM.
Senior Member
Re: About Zorder
Reply #6 - Feb 24th, 2011 at 10:35pm
Your example work perfect for move in z order multiple nodes selected, but what about move with keyboard?
DiagramNode node = form.ActiveItem as DiagramNode;
               if (node != null)
                   node.Move(node.Bounds.X -1, node.Bounds.Y);
How move multiple items and not single?
Re: About Zorder
Reply #7 - Feb 25th, 2011 at 7:28am
Likewise, iterate over Selection.Nodes and call node.Move from the loop body.
PDM.
Senior Member
Re: About Zorder
Reply #8 - Feb 25th, 2011 at 9:17am
Thankyou work perfect !
