Hot Topic (More than 10 Replies) treeviewlayout (Read 7874 times)
chimakurthi
treeviewlayout
Feb 24th, 2011 at 2:23pm
hi,
sorry i am totally new in mindfusion diagraming.
i need to draw treenodes showing joins spreading in no of columns  and rows.
which is better layout and how can i use it. how to add to specify differnt row and columns at run time
i didnt find any help for this online
thanks  ???
Re: treeviewlayout
Reply #1 - Feb 24th, 2011 at 3:27pm
Do you mean you are using the TreeViewNode class? It can display only one column, and the number of rows depends on the number of items in TreeViewNode.RootItems and their children. If you need to show more columns of data, you could use TableNodes. For best results arranging both kinds of nodes, use LayeredLayout with Orientation set to Horizontal.
chimakurthi
Re: treeviewlayout
Reply #2 - Feb 24th, 2011 at 3:46pm
hi,
thank you for reply.
sorry its mindfusion diagramming showing table nodes with joinlinks
just boiling my head to do it from morning.
but how can i specify it can i have any example for layerd layout usage can i add table nodes to different layers at run time.
my requirement is adding tablenode to different layer depends on join sequesnce
means join sequence of tablenode
1 means in column 1
2 means in column 2
3 in column 3 so on ..up to 10 columns
each columns can have no of table nodes
please give me sample if possible
thanks
Embarrassed
Re: treeviewlayout
Reply #3 - Feb 24th, 2011 at 3:54pm
Set LayeredLayout.EnableCustomLayers = true and assign your join number to node.LayoutTraits[LayeredLayoutTraits.Layer]. This won't work if you have links between tables on the same layer. If you need that, try using a vertical SwimlaneLayout instead, where the join number is assigned to LayoutTraits[SwimlaneLayoutTraits.Lane]. Note that for both layout classes the Layer/Lane indices are zero-based.
chimakurthi
Re: treeviewlayout
Reply #4 - Feb 24th, 2011 at 4:13pm
hi,
yes there are links between nodes in same layer and and doesnt show SwimlaneLayout Class in our version
what should i do...?
thanks
Regards
Re: treeviewlayout
Reply #5 - Feb 24th, 2011 at 5:16pm
Try setting IgnoreLayout = true on such links. Then you will have to implement some additional processing for them after calling Arrange(), to set their control points appropriately to avoid crossing the tables.
chimakurthi
container control
Reply #6 - Feb 25th, 2011 at 10:07am
hai
how can i set the contianer control at the bottom of the diagram...?
i created using
diagram1.factory.createcontainernode(10,100,diagramview1.width,40)
i tried by setting different x,y co-ordinates but still floating to top or spreading till bottom
is there any float property..?
thanks
Re: treeviewlayout
Reply #7 - Feb 25th, 2011 at 10:42am
After creating and arranging the previous nodes, call GetContentBounds() to find the bounding rectangle for all content in the diagram. Then create the container at (10, contentRect.Bottom + some_offset).
chimakurthi
Re: treeviewlayout
Reply #8 - Mar 1st, 2011 at 3:40pm
hi,
some nodes are added to container in between
some to diagram so how  can i display container at bottom of diagram before adding nodes
thanks
Re: treeviewlayout
Reply #9 - Mar 1st, 2011 at 4:10pm
You could place it at Y = diagram.Bounds.Bottom - container.Bounds.Height.
chimakurthi
Re: treeviewlayout
Reply #10 - Mar 1st, 2011 at 4:21pm
hi,
container = diagram1.Factory.CreateContainerNode(0,diagram1.Bounds.Bottom-container.bounds.h
eight,500,20);
gives error as container is not created before. and null reference error
thanks
Re: treeviewlayout
Reply #11 - Mar 1st, 2011 at 4:50pm
Ok, try with diagram1.Factory.CreateContainerNode(0,diagram1.Bounds.Bottom-20,500,20);
chimakurthi
Re: treeviewlayout
Reply #12 - Mar 1st, 2011 at 5:38pm
Hi
thank for response.
i did call setbound()
but nodes addded to container are not getting position in it i need to minimise and the maxmise then it is. they look like hanging at the border of container
what method i need to refresh that
thanks
Re: treeviewlayout
Reply #13 - Mar 1st, 2011 at 6:23pm
Call container.UpdateBounds() after adding its child nodes.
vasundhara
Re: treeviewlayout
Reply #14 - Mar 9th, 2011 at 11:13am
Hi
how can i set the scroll bars property for container.
is any property available
and i set the container and node are added on top basing on points but not added to container
when i click container it hides the nodes.how can i set that so that i doesnt come to front it just for appearance
thanks
