Hot Topic (More than 10 Replies) treeviewlayout (Read 7868 times)
vasundhara
Re: treeviewlayout
Reply #15 - Mar 9th, 2011 at 1:06pm
hi,
i did solve the above by adding nodes to container and set contanier autoshrink=true
how can i draw aline between contanier to a node ?
i was unable to select link once node are added to the container..?
thanks
Re: treeviewlayout
Reply #16 - Mar 9th, 2011 at 2:03pm
Make sure the container is at the back of Z order, and set Diagram.HitTestPriority = ZOrder.
vasundhara
Re: treeviewlayout
Reply #17 - Mar 9th, 2011 at 3:22pm
hi,
how to draw a single line beetween container and tree node
thanks
Re: treeviewlayout
Reply #18 - Mar 9th, 2011 at 3:52pm
Do you mean a link between the container and node? It should look like diagram.Factory.CreateDiagramLink(container, node);
