Normal Topic Give the node from contextMenuStrip to Event? (Read 1349 times)
moelski
Mar 3rd, 2011 at 3:27pm
Hi !
I have this Event to detect a right click and open up the context menu:
private void diagram_NodeClicked(object sender, NodeEventArgs e)
  if (e.MouseButton == MouseButton.Right)
     contextInput.Show(MousePosition);
e.node give me access to the corresponding node.
But how can I access this node if the user clicks on a context menu entry?
Greetz
Dominik
Re: Give the node from contextMenuStrip to Event?
Reply #1 - Mar 3rd, 2011 at 3:34pm
Store a reference to it in a field of the form class; see the SiteMap sample project for an example. Or perhaps you could set it as Tag value of the ContextMenu object.
