Normal Topic Environment issue for OS / Browser? (Read 3847 times)
chieh
Mar 4th, 2011 at 3:12pm
Dear Sir/Madam,
The service contains NetDiagram Trial Version 3.1.1 had been deployed well and now we did some OS and browser’s test, and criteria shows in the following.
1. Microsoft Windows XP Professional with Explorer 8.0 / Firefox/3.5.16 / Java Plug-in 1.6.0_24
Using JRE version 1.6.0_24-b07 Java HotSpot(TM) Client VM
2. Microsoft Windows 7 Professional with Explorer: 9 (beta) 9.0.7930.16406 / Firefox: 3.6.14/ Java Plug-in 1.6.0_24
It works fine in XP system with IE 8.0 Firefox/3.5.16when user CRUD visual diagrams.
However some issues need to be identified when using OS in Window 7 Professional with Explorer: 9 (beta) 9.0.7930.16406 / Firefox: 3.6.14
Issue 1 - Create an icon by using drag a shape from ShapeListBox to DiagramView cannot trigger javascript code.
Issue2 - Double click on node cannot trigger javascript code.
this is aspx page:
<table width="100%">
<ndiag:DiagramView ID="VSDiagramView" runat="server" Height="610px" Width="800px" NodeCreatedScript="onNodeCreated"
NodeDoubleClickedScript="onNodeDoubleClicked" ShapeLibraryLocation="LeanIcons.shl" BackColor="Transparent"
BorderColor="Transparent" LinkCreatedScript="onLinkCreated">
<Diagram LinkHeadShape="PointerArrow" LinkBrush="s:#FFA9A9A9" LinkCrossings="Arcs" LinkHeadShapeSize="3"
LinkStyle="Bezier" BackBrush="s:#FFFFFFFF" />
</ndiag:DiagramView>
<ndiag:ShapeListBox ID="ShapeListBox1" runat="server" Height="450px" Style="background-color: white"
Width="200px" ShapeLibraryLocation="LeanIcons.shl">
</ndiag:ShapeListBox>
<ndiag:Overview ID="Overview1" runat="server" DiagramViewID="VSDiagramView" Height="150px" Style="background-color: silver"
Width="200px" />.....
</table>
<script language="javascript" type="text/javascript">
function onNodeCreated(sender, args)
var node = args.getNode();
node.setTag(getUniqueId());
node.setText("");
args.getNode().getTextFormat().setWrapAtCharacter(false);
<%=VSDiagramView.AppletElement%>.getDiagramView().beginEdit(node);
function onNodeDoubleClicked(sender, args)
var applet = <%= VSDiagramView.AppletElement %>;
document.getElementById("ctl00_ContentPlaceHolder1_editNode").value = args.getNode().getTag();
<%= postbackMethod %>;
</script>
chieh
Re: Environment issue for OS / Browser?
Reply #1 - Mar 4th, 2011 at 3:14pm
Error comes out from java console and shows it below,
No such method "onNodeCreated" on JavaScript object
netscape.javascript.JSException: No such method "onNodeCreated" on JavaScript object
at sun.plugin2.main.client.MessagePassingJSObject.newJSException(Unknown Source)
at sun.plugin2.main.client.MessagePassingJSObject.waitForReply(Unknown Source)
at sun.plugin2.main.client.MessagePassingJSObject.call(Unknown Source)
at com.mindfusion.diagramming.AppletEx.a(Unknown Source)
at com.mindfusion.diagramming.DiagramApplet.a(Unknown Source)
at com.mindfusion.diagramming.DiagramApplet.nodeCreated(Unknown Source)
at com.mindfusion.diagramming.Diagram$13.raise(Unknown Source)
at com.mindfusion.diagramming.Diagram.a(Unknown Source)
at com.mindfusion.diagramming.Diagram.b(Unknown Source)
at com.mindfusion.diagramming.DiagramTransferHandler.importData(Unknown Source)
at javax.swing.TransferHandler.importData(Unknown Source)
at javax.swing.TransferHandler$DropHandler.drop(Unknown Source)
at java.awt.dnd.DropTarget.drop(Unknown Source)
at javax.swing.TransferHandler$SwingDropTarget.drop(Unknown Source)
at sun.awt.dnd.SunDropTargetContextPeer.processDropMessage(Unknown Source)
at sun.awt.dnd.SunDropTargetContextPeer$EventDispatcher.dispatchDropEvent(Unknown Source)
at sun.awt.dnd.SunDropTargetContextPeer$EventDispatcher.dispatchEvent(Unknown Source)
at sun.awt.dnd.SunDropTargetEvent.dispatch(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processDropTargetEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$2.run(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
chieh
Reply #2 - Mar 4th, 2011 at 3:14pm
No such method "onNodeDoubleClicked" on JavaScript object
netscape.javascript.JSException: No such method "onNodeDoubleClicked" on JavaScript object
at com.mindfusion.diagramming.DiagramApplet.nodeDoubleClicked(Unknown Source)
at com.mindfusion.diagramming.Diagram$16.raise(Unknown Source)
at com.mindfusion.diagramming.Diagram.raiseDoubleClicked(Unknown Source)
at com.mindfusion.diagramming.DiagramView.a(Unknown Source)
at com.mindfusion.diagramming.DiagramView$MouseMonitor.mousePressed(Unknown Source)
at java.awt.AWTEventMulticaster.mousePressed(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
Any suggestions for 2’s environment?
Many thanks
Reply #3 - Mar 4th, 2011 at 3:47pm
Is that exception thrown in both browsers or just IE9 beta? Our developer has just tried the Flowcharter example, which has an onNodeCreated handler, and it worked fine under Firefox 3.6.14. We can try it under IE9 next week.
chieh
Reply #4 - Mar 4th, 2011 at 3:55pm
I had tested it again, it only happened in IE 9 Beta
Firefox works fine now. many thanks.
Reply #5 - Mar 8th, 2011 at 2:38pm
What JRE and IE build numbers do you have on the Win7 system? onNodeCreated worked fine for us with the following versions on 64-bit Win 7:
JRE: 1.6.0_24-b07
IE9: 9.0.8080.16413
Perhaps also check if JavaScript isn't turned off in the IE settings by some chance.
chieh
Reply #6 - Mar 11th, 2011 at 4:24pm
Hello
the environment on win7 is below,
I will check JS setting of IE to make sure of that
cheers
Reply #7 - Mar 14th, 2011 at 7:25am
It seems you have an older IE9 build. Please try that with the latest version.
