Hot Topic (More than 10 Replies) Some strange problem (Read 6703 times)
Hunter
Mar 9th, 2011 at 12:14pm
Hello, Stoyo. I have the Hashtable which keeps the Diagram objects with Int32 values as keys of the Hashtable. And also I have some functions:
	  public static int PutDiagramToHashTable(Diagram a_Diagram)
		m_DiagramsTable.Add(m_nDiagramIndex, a_Diagram);
		return m_nDiagramIndex++;
	  public static Diagram GetDiagramFromHashTable(int a_nDiagramId)
		if (m_DiagramsTable.ContainsKey(a_nDiagramId))
		    return m_DiagramsTable[a_nDiagramId] as Diagram;
		return null;
When I call the GetDiagramFromHashTable function I receive the necessary Diagram object which keeps the nodes which I expect. But when I try to set this object to my Diagram in the user control I see the clear Diagram and there are no exceptions...
m_Diagram = App.GetDiagramFromHashTable(nIdx);
where m_Diagram is an object in the user control for displaying diagram.
Re: Some strange problem
Reply #1 - Mar 9th, 2011 at 1:47pm
Hi. Shouldn't you also replace the diagram in the usercontrol's root panel? I.e. remove the old one from panel.Children and add the one returned by GetDiagramFromHashTable.
Hunter
Reply #2 - Mar 9th, 2011 at 2:27pm
Yes, I can do this, but I made the following.
				Diagram dgrm = App.GetDiagramFromHashTable(nIdx);
				MemoryStream stream = Utils.SaveDiagram(dgrm);
				stream.Position = 0;
				Utils.RestoreDiagram(stream.ToArray(), m_Diagram);
Save and Restore functions calls LoadFromString and SaveToString methods. After that all works nice but slowly when objects are large
Hunter
Reply #3 - Mar 9th, 2011 at 4:08pm
I have another problem. I have an MDI interface with 2 user controls in 2 MDI windows. Each user control keeps the Diagram object. I select one derived from ShapeNode object and copy it into clipboard.
public void Copy_Executed(object sender, ExecutedRoutedEventArgs e)
		List<DiagramLink> deselectedLinks = ExcludeUnconnectedLinksFromSelection();
		m_Diagram.CopyToClipboard(false);
		foreach (DiagramLink link in deselectedLinks)
		    m_Diagram.Selection.Links.Add(link);
After that I try to paste them into the another user control with another Diagram object. The code is the following:
CompositeCmd undoCommand = new CompositeCmd(m_Diagram, UndoCommands.AddNode);
		m_Diagram.PasteFromClipboard(new Vector(50, 50), false);
		List<ReassignedHids> hids = new List<ReassignedHids>();
		foreach (DiagramNode node in m_Diagram.Selection.Nodes)
		    AddItemCmd cmd = new AddItemCmd(node);
		    undoCommand.AddSubCmd(cmd);
		    if (node is TPDENode)
			  TPDENode tpdeNode = node as TPDENode;
			  if (tpdeNode.ShadowProps.ShowShadows)
				DropShadowEffect effect = new DropShadowEffect();
				effect.Color = tpdeNode.ShadowProps.ShadowColor;
				effect.ShadowDepth = tpdeNode.ShadowProps.ShadowDepth;
				tpdeNode.Effect = effect;
				tpdeNode.Repaint(false);
			  if (node is TechnologicalOperation)
				TechnologicalOperation operation = node as TechnologicalOperation;
				ReassignedHids hid = new ReassignedHids(operation.Id, Id.GetDescendant(LastAssignedId, SqlHierarchyId.Null));
				hids.Add(hid);
				operation.Id = Id.GetDescendant(LastAssignedId, SqlHierarchyId.Null);
				LastAssignedId = operation.Id;
				BreadCrumbProcessDescription desc = new BreadCrumbProcessDescription(operation.Text, operation.Id,
				    NodeType.SimpleProcess);
				AddProcessToBreadcrumb(desc);
			  else if (node is OperationGroupNode)
				OperationGroupNode operationGrp = node as OperationGroupNode;
				ReassignedHids hid = new ReassignedHids(operationGrp.Id, Id.GetDescendant(LastAssignedId, SqlHierarchyId.Null));
				hids.Add(hid);
				operationGrp.Id = Id.GetDescendant(LastAssignedId, SqlHierarchyId.Null);
				LastAssignedId = operationGrp.Id;
				BreadCrumbProcessDescription desc = new BreadCrumbProcessDescription(operationGrp.Text,
				    operationGrp.Id, NodeType.ComplexProcess);
		e.Source = hids;
		try
		    undoCommand.Execute();
		catch (Exception ex)
After that I catch the exception "Must disconnect specified child from current parent Visual before attaching to new parent Visual." When I do the same within one Diagram object all works ok
Reply #4 - Mar 9th, 2011 at 7:04pm
What's shown at the top of the exception's stack trace? Copy and paste worked for me between two diagrams with standard ShapeNodes.
Hunter
Reply #5 - Mar 10th, 2011 at 7:11am
I have used th your source codes and seen that the exception take place after AddVisualChild(v); in the method internal void AddVisual(Visual v) of the class TranslateLayer: FrameworkElement. In the output console it looks like the following
Step into: Stepping over method without symbols 'System.Collections.CollectionBase.Count.get'
Step into: Stepping over property 'MindFusion.Diagramming.Wpf.DiagramItem.UIElement.get'.  To step into properties, go to Tools->Options->Debugging and uncheck 'Step over properties and operators (Managed only)'.
Step into: Stepping over property 'MindFusion.Diagramming.Wpf.DiagramItem.Adorner.get'.  To step into properties, go to Tools->Options->Debugging and uncheck 'Step over properties and operators (Managed only)'.
Step into: Stepping over method without symbols 'System.Windows.Media.Visual.AddVisualChild'
A first chance exception of type 'System.ArgumentException' occurred in PresentationCore.dll
For doing the same with standard ShapeNode object I need to modify my code. So it will take some time
Reply #6 - Mar 10th, 2011 at 9:48am
Actually doesn't your code add the just pasted nodes for a second time to m_Diagram? The Paste method adds them once, and then the AddItemCmds created in the foreach loop.
Hunter
Reply #7 - Mar 10th, 2011 at 11:08am
No. I only one time call m_Diagram.PasteFromClipboard(new Vector(50, 50), false);
Hunter
Reply #8 - Mar 10th, 2011 at 11:31am
When I try to do the same with simple rect ShapeNode I see the same: A first chance exception of type 'System.ArgumentException' occurred in PresentationCore.dll with message "Must disconnect specified child from current parent Visual before attaching to new parent Visual."
Reply #9 - Mar 10th, 2011 at 11:36am
However the foreach loop after that adds the pasted nodes again, if you are still using the code posted above. I suppose you will get such exceptions in that case.
Hunter
Reply #10 - Mar 10th, 2011 at 11:49am
The foreach loop doesn't add nodes again. It still set some properties and modify some other controls (if you keep in mind the loop: foreach (DiagramNode node in m_Diagram.Selection.Nodes)
Reply #11 - Mar 10th, 2011 at 12:33pm
What do you think the AddItemCmd commands created in that loop do? I have added the command to my test and it throws that exception indeed:
diagram.PasteFromClipboard(new Vector(10, 10));
diagram.ExecuteCommand(new AddItemCmd(diagram.Selection.Nodes[0]));
Otherwise it works fine if you remove the AddItemCmd line.
Hunter
Reply #12 - Mar 10th, 2011 at 12:39pm
But in this case how I have to organize the Undo/Redo operations if I need to undo all pasted item in one transaction? And also when I undo paste operation I need to know which nodes removes from diagram to sunchronize the diagram with my TreeView and Breadcrumb control?
Reply #13 - Mar 10th, 2011 at 1:10pm
PasteFromClipboard already does that as an atomic operation. It creates a composite command internally with AddItemCmds for each item, so synchronizing with your other controls should not be any different from what you are doing now (in response to ActionUndone I guess?).
« Last Edit: Mar 11th, 2011 at 7:30am by Stoyo »
