Normal Topic How get and set position of node? (Read 4346 times)
PDM.
Senior Member
Mar 9th, 2011 at 5:54pm
var Object = new MyCustomObject();
var node = new DiagramNodeAdapter(form, Object);
double PositionX = node.Bounds.X;
double PositionY = node.Bounds.Y;
If im not wrong i have the X and Y position of that node.
Now i need do some calcs, and reposition that node programtically.
How reposition the node?
This is the only one kind of node on the screen, i not have multile nodes of same kind juts only one.
But how can reposition?
I need reposition programatically on the screen after do some calcs with PositionX PositionY
I asume can be done using
node.Bounds = new Rect(newYvalue, newXvalue, W, H);
//my calcs here with PositonX and positionY
But this not work.
Re: How get and set position of node?
Reply #1 - Mar 9th, 2011 at 7:08pm
I suppose you should swap the newYvalue, newXvalue argument positions. X comes first, then Y...
PDM.
Senior Member
Reply #2 - Mar 9th, 2011 at 7:25pm
I know, just a typo error.
node.Bounds = new Rect(X,  Y,  W,  H);
Anyway not work!
What im doing for move is correct?
Why node not moved?
Reply #3 - Mar 9th, 2011 at 7:33pm
Because X,Y is the same as the node's initial position?
PDM.
Senior Member
Reply #4 - Mar 9th, 2011 at 7:42pm
Simple test
Onload i create the node:
var Object = new MyNode();
if (Object != null)
Object.ButtonClick1 += new RoutedEventHandler(Click1);
Object.ButtonClick2 += new RoutedEventHandler(Click2);
node.Bounds = new Rect(100, 100, 34, 40);
form.Nodes.Add(node);
Just for test i add  a simple button, and use code for move, but not work
private void button1_Click(object sender, RoutedEventArgs e)
node.Bounds = new Rect(0, 0, 34, 40);
What im doing wrong? Tongue
Reply #5 - Mar 9th, 2011 at 7:54pm
The node you create in button1_Click is not the same as the one in OnLoad, and it's even not shown in the diagram.
PDM.
Senior Member
Reply #6 - Mar 9th, 2011 at 11:04pm
How can access to the node already created with code run onload and move programatically?
Thankyou for your patience!!
« Last Edit: Mar 10th, 2011 at 12:28am by PDM. »
Reply #7 - Mar 10th, 2011 at 7:07am
Store a reference to it in a field of the form class:
DiagramNode node;
OnLoad()
     node = new DiagramNodeAdapter(...
OnClick()
     node.Bounds = ...
If this is always the first node your app creates, you could also access it through diagram.Nodes[0].
