Normal Topic node font (Read 1549 times)
hadni
node font
Mar 11th, 2011 at 4:36am
helo, i have a question here.
I want to make the font size in the node change if the node resized.. so if i resize the node into a bigger size, the font size will get bigger too..
how can i do that? is anyone know?
thank's a bunch..
Re: node font
Reply #1 - Mar 11th, 2011 at 7:42am
If you need to display only a single line of text, you could do this:
private void diagram_NodeModifying(object sender, NodeValidationEventArgs e)
	e.Node.Font = new Font(e.Node.Font.FontFamily,
		e.Node.Bounds.Height * 2 / 3, GraphicsUnit.Millimeter);
Or otherwise you could scale the text proportionally to the change in height of the node. You will have to keep the original node size in that case.
hadni
Re: node font
Reply #2 - Mar 11th, 2011 at 9:19am
thank you so much Grin Grin Grin Grin Grin
