System.Windows.Markup.XamlParseException was unhandled
Message='Cannot set unknown member '{
http://schemas.microsoft.com/expression/2010/drawing}ShapeImplementation.ShouldF...'.' Line number '1' and line position '708'.
Source=PresentationFramework
LineNumber=1
LinePosition=708
StackTrace:
at System.Windows.Markup.XamlReader.RewrapException(Exception e, IXamlLineInfo lineInfo, Uri baseUri)
at System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri)
at System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, Boolean skipJournaledProperties, Uri baseUri)
at System.Windows.Markup.XamlReader.Load(XamlReader xamlReader, ParserContext parserContext)
at System.Windows.Markup.XamlReader.Load(XmlReader reader, ParserContext parserContext, XamlParseMode parseMode)
at System.Windows.Markup.XamlReader.Load(XmlReader reader)
at MindFusion.Diagramming.Wpf.DiagramNodeAdapter.xb346c580af9eaf57(UIElement x4bbc2c453c470189)
at MindFusion.Diagramming.Wpf.DiagramNodeAdapter..ctor(DiagramNodeAdapter prototype)
at MindFusion.Diagramming.Wpf.DiagramNodeAdapter.Clone(Boolean clipboard)
at MindFusion.Diagramming.Wpf.Diagram.CopySelection(Diagram source, Boolean unconnectedLinks, Boolean copyGroups)
at MindFusion.Diagramming.Wpf.Diagram.CopyToClipboard(Boolean persist, Boolean groups)
at MindFusion.Diagramming.Wpf.Diagram.xf89f70209334cdd5(Object xe0292b9ed559da7d, ExecutedRoutedEventArgs xce8d8c7e3c2c2426)
at System.Windows.Input.CommandBinding.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
at System.Windows.Input.CommandManager.ExecuteCommandBinding(Object sender, ExecutedRoutedEventArgs e, CommandBinding commandBinding)
at System.Windows.Input.CommandManager.FindCommandBinding(CommandBindingCollection commandBindings, Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
at System.Windows.Input.CommandManager.FindCommandBinding(Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
at System.Windows.Input.CommandManager.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
at System.Windows.UIElement.OnExecutedThunk(Object sender, ExecutedRoutedEventArgs e)
at System.Windows.Input.ExecutedRoutedEventArgs.InvokeEventHandler(Delegate genericHandler, Object target)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted)
at System.Windows.Input.RoutedCommand.ExecuteImpl(Object parameter, IInputElement target, Boolean userInitiated)
at System.Windows.Input.RoutedCommand.ExecuteCore(Object parameter, IInputElement target, Boolean userInitiated)
at System.Windows.Input.CommandManager.TranslateInput(IInputElement targetElement, InputEventArgs inputEventArgs)
at System.Windows.UIElement.OnKeyDownThunk(Object sender, KeyEventArgs e)
at System.Windows.Input.KeyEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
at System.Windows.Input.InputManager.ProcessStagingArea()
