Normal Topic how box use picture with a memory ? (Read 2134 times)
strong_peng
Mar 31st, 2011 at 2:53am
i load picture in memory before flowchart start.
i want to load picture from memory .
how use box.setpicture function?
CTopoPicture how load picture?
Re: how box use picture with a memory ?
Reply #1 - Mar 31st, 2011 at 7:43am
You must create an OLE StdPicture object from the bitmap bytes. Using Win32 API, that can be done by calling CreateStreamOnHGlobal to create an IStream object from the byte array, and then OleLoadPicture to load the image from the IStream. You can find an example here:
http://www.codeproject.com/KB/graphics/render.aspx
