Normal Topic getOriginAnchor() problem (Read 4321 times)
cpmjones
Mar 31st, 2011 at 10:23am
I use getOriginAnchor() to determine where a link is connected to it's origin node.
After applying a layout algorythm (e.g. Flowchart) the link's origin changes but getOriginAnchor() returns the same index as before.
Is this correct?
Chris
Re: getOriginAnchor() problem
Reply #1 - Mar 31st, 2011 at 10:52am
Set Layout.Anchoring to Reassign if the layout code should align links to anchor points. The Ignore option ignores the anchor point positions but does not remove their association with the links.
cpmjones
Reply #2 - Mar 31st, 2011 at 12:39pm
Hi Stoyo,
thanks again for your quick response.
Unfortunately it appears to ignore whichever anchoring value I set.
Is there any other setting which may be affecting this?
Chris
Reply #3 - Mar 31st, 2011 at 2:11pm
Are you calling routeAllLinks() after arrange()? The routing function considers the RoutingOptions.Anchoring value.
cpmjones
Reply #4 - Mar 31st, 2011 at 2:19pm
Hi Stoyo,
here is my code:
[code]
FlowchartLayout fl = new FlowchartLayout();
fl.setIgnoreRepeatingLinks(false);
fl.setOrientation(Orientation.Auto);
fl.setAnchoring(Anchoring.Reassign);
fl.arrange(diagram);
diagram.routeAllLinks();
[/code]
Chris
Reply #5 - Mar 31st, 2011 at 5:45pm
Hi Chris,
Set it on the RoutingOptions object too and routeAll will align the links to anchor points:
diagram.getRoutingOptions().setAnchoring(Anchoring.Reassign);
cpmjones
Reply #6 - Apr 4th, 2011 at 9:17am
That worked, thanks!  Smiley
