Normal Topic install error - "could not open registry key& (Read 5973 times)
sbv
Apr 6th, 2011 at 4:15pm
Unfortunately I am unable to install the program.
I get the following error message:
Could not open key:
HKEY_LOCAL_MACHINE\Software\Classes\Msxml2.DOMDocument.4.0.  Verify that you have sufficient access to that key, or contact your support personnel.
I have installed MS XML 4.0 from the Microsoft website, thinking that would solve the problem, but the error persists.  Please advise.
Re: install error - "could not open registry
Reply #1 - Apr 6th, 2011 at 4:31pm
Hi, What Windows version are you using?
sbv
Reply #2 - Apr 6th, 2011 at 5:50pm
Hi,  I am using Windows XP SP3.
Reply #3 - Apr 7th, 2011 at 10:05am
Can you try with this executable and see if it works:
https://mindfusion.eu/_temp/XMLViewer.zip
There is no need to install it, simply unzip it somewhere.
sbv
Reply #4 - Apr 7th, 2011 at 3:25pm
Works a charm - thank you!
