Hot Topic (More than 10 Replies) Inherit from DiagramLink (Read 12213 times)
Amosius
Apr 11th, 2011 at 2:46pm
I would like to create a class which inherits from DiagramLink
    internal class ConnectionLink : DiagramLink
        private bool iscolumn;
        private bool isrow;
        public bool IsColumn
            get { return iscolumn; }
            set { iscolumn= value; }
        public bool IsRow
            get { return isrow; }
            set { isrow= value; }
        public ConnectionLink(Diagram parent)
            : base(parent)
When i now create a link in the Diagram, i would like to create an object from this class instead of an DiagramLink. So I can use the following code:
            var nodes = from DiagramNode node in MyDiagram.Nodes select node;
            foreach (ShapeNode node in nodes)
                DiagramLinkCollection link = node.OutgoingLinks;
                for (int i = 0; i < link.Count; i++)
                    ((ConnectionLink)link[i]).IsColumn = true;
Any ideas, what's the trick for this?
Re: Inherit from DiagramLink
Reply #1 - Apr 11th, 2011 at 4:31pm
Do you need to create such links from code or interactively? If from code, create an instance, set its Origin and Destination properties and add it to Diagram.Links. To let the user draw such links, create a custom behavior class and override its CreateLink method.
Amosius
Reply #2 - Apr 13th, 2011 at 5:28pm
Creation will be interactively. Thx for your help.
Reply #3 - Apr 13th, 2011 at 6:21pm
Ok, so it should look like this:
class MyBehavior : LinkShapesBehavior
	public MyBehavior(Diagram diagram) : base(diagram) {}
	protected override DiagramLink CreateLink()
		return new ConnectionLink(Diagram);
diagram.CustomBehavior = new MyBehavior(diagram);
Amosius
Reply #4 - Apr 19th, 2011 at 9:34am
Hi Stoyan,
works fine.
But the Behavior of the mouse action on the diagram changed. Now the diagram draws a default shapenode, instead of a selection box (such like Behavior.Modify).
How do i get the Behavior.Modify and keep my custom DrawLinksBehavior?
diagram.Behavior = Behavior.Custom;
diagram.Behavior = Behavior.DrawLinks
Thx. Amosius
Reply #5 - Apr 19th, 2011 at 9:44am
Inherit the custom class from DrawLinksBehavior instead of LinkShapesBehavior. All predefined Behavior.* members have a corresponding *Behavior class you could derive from if it's most similar to the custom functionality you need.
Amosius
Reply #6 - Apr 19th, 2011 at 12:06pm
Works like a charm. Thanks for your support.
Pontius
Reply #7 - Nov 7th, 2011 at 5:03pm
I have a BoundDiagramLink derived from DiagramLink and I also set the diagram's Behavior to
    public class DrawBoundLinksBehavior : DrawLinksBehavior
        public DrawBoundLinksBehavior(Diagram diagram) : base(diagram) { }
            return new BoundDiagramLink(Diagram);
in order to get my own BoundDiagramLinks.
I use the BoundDiagramLinks to separate the Link's data from the view and hold them in a model.
The model data is an additional Origin/DestinationID containing GuIDs that are stored in the MyNode classes Tag also.
The BoundDiagramLink also have the Origin/DestinationIndex which is already part of the DiagramLink class.
Let's only look at the OriginIndex in BoundDiagramLink:
    public class BoundDiagramLink : DiagramLink
        public static readonly DependencyProperty OriginIndexProperty = DependencyProperty.Register(
            "OriginIndex",
            typeof(int),
            typeof(BoundDiagramLink),
            new PropertyMetadata(""));
        public BoundDiagramLink(Diagram parent) : base(parent) { }
        public BoundDiagramLink(Diagram parent, DiagramNode origin, DiagramNode destination)
            : base(parent, origin, destination)
When the BoundDiagramLink is created in my Behavior class I run in an exception
"Default value type does not match type of property: OriginIndex".
What am I doing wrong?
Pontius
Reply #8 - Nov 7th, 2011 at 6:15pm
The defaultValue argument you pass to the PropertyMetadata constructor should have the type of the property. I suppose you should specify an integer value instead of the empty string.
Pontius
Reply #9 - Nov 14th, 2011 at 5:24pm
Hi Stoyo,
thanks. Of course it works with an integer as defaultValue. I shouldn't do as much copy and paste.
I want to bind some DiagramLinks properties that describe the link.
These values are:
1. OriginIndex
2. DestinationIndex
3. OriginNodeID (that is a string that I also store inside the DiagramNodes Tag value)
4. DestinationNodeID (dito)
5. ControlPoints
If have already implemented binding for the values 1 to 4 since it is straight forward programming.
The ControlPoints are not as easy for me. Actually I do not need the first and the last ControlPoint
since these points are defined by the Nodes already.
Do you have a sample how to have data binding beween these ControlPoints and the data in my model using data binding?
Or do you have some hints how to implement that?
Thanks in advance.
Pontius
Reply #10 - Nov 15th, 2011 at 4:40pm
You could add a new dependency property for binding of the type you need, e.g. BoundPoints, and assign to it from an OnSizeChanged override. OnSizeChanged is called every time the link's internal ControlPoints change. Alternatively, you could try raising PropertyChanged("ControlPoints") from the override and bind to ControlPoints using a value converter.
Pontius
Reply #11 - Nov 18th, 2011 at 1:04pm
Hi Stoyo,
I did it according to your first proposal and it seems to work. Thanks.
Updating the ControlPoints is still an issue when the number of ControlPoints change.
I use the SegmentCount property to change the number of ControlPoints.
When I step through the code the SegmentCount may have a value of 5,
then I set it to the value of let's say 8. But it stays at 5 and the ControlPoints.Count is still 6.
So I run in an error when I try to access the seventh ControlPoint:
ControlPoint[6] = ...
    BoundDiagramLink link = new BoundDiagramLink(diagram, origin, destination);
    link.SetControlPoints(InnerControlPoints);
    public void SetControlPoints(innerControlPoints)
    if (innerControlPoints.Count > 0 && ControlPoints.Count > 1)
        Point firstPoint = ControlPoints[0];
        Point lastPoint = ControlPoints[ControlPoints.Count - 1];
        SegmentCount = (short)(innerControlPoints.Count + 1); // without effect
        ControlPoints[0] = firstPoint;
        ControlPoints[ControlPoints.Count - 1] = lastPoint;
        for (int i = 0; i < innerControlPoints.Count; i++)
            ControlPoints[i + 1] = innerControlPoints[i];
(Notice that my InnerControlPoints are the normal ControlPoints without the ends that are defined by the Nodes AnchorPoints already. But that's not the point here.)
How can I change the number of ControlPoints?
Pontius
Reply #12 - Nov 18th, 2011 at 2:36pm
I think you can't set SegmentCount if AutoRoute is enabled. If routing is enabled, try turning it off temporarily. Alternatively, add points directly to ControlPoints, and call the UpdateFromPoints overload that takes an updateSegmentCount argument.
Pontius
Reply #13 - Nov 18th, 2011 at 3:56pm
Hi Stoyo,
temporarily switching the DiagramLinks AutoRoute to false somehow leads to rerouting of the link.
However, switching the Diagram.RouteLinks to false, creating the links and switching back to true seems to work.
Regards
Pontius
Pontius
Reply #14 - Nov 18th, 2011 at 4:37pm
Hm, it seems switching Diagram.RouteLinks temporarily to false and back to true again leads to different behaviour after switching.
After moving a DiagramNode which is connected to a DiagramLink I trigger on the DiagramLink.OnSizeChanged event and use the ControlPoints.GetArray() to update my model. I get the OnSizeChanged event several times. I can follow the changes in the ControlPoints array until the link gets only rectangular angles.
After switching Diagram.RouteLinks to false and true again the OnSizeChanged event does not come in as often and the last ControlPoints array does still contain an angle that is not rectangular.
Pontius
