Normal Topic Item context menu + doubleclick (Read 3753 times)
Lemings
Apr 12th, 2011 at 10:41am
I am a bit lost again, so it would be great if anybody could help me Smiley
I have 2 problems:
1. how to handle doubleclick of the item in TimeTable view? I would like to open details of the item, but DoubleClick event of calendar doesn't (or i can't see) return the xy coordinates or selected item and i don't see doubleclick in item events.
2. how can i add a context menu to an item? If i add it to a calendar control, i can't get back which item has been selected. I (or the customer...) would like to change some properties of the event by rightclicking the item and changing it in a menu
Thanks a lot for your work!
Re: Item context menu + doubleclick
Reply #1 - Apr 12th, 2011 at 11:01am
You need to handle the ItemClicked event of the Calendar - it fires for all sort of item clicks - left/right, single/double. Then check the appropriate properties of the event argument to determine the click type. The following example shows how:
if (e.Clicks == 2 && e.Button == MouseButtons.Left)
      calendar1.ResetDrag();
      MessageBox.Show(e.Item.HeaderText + " has been double-clicked.");
else if (e.Button == MouseButtons.Right)
      MessageBox.Show(e.Item.HeaderText + " has been right-clicked - show menu.");
Let me know if this helps.
Lemings
Reply #2 - Apr 12th, 2011 at 11:34am
Hi Meppy, thanks a lot, it works!
One more little question - after i right click, i'd like to display the menu at the position where i have clicked it. But eventargs return position inside the item. Can I get the x,y of an item? I know how to do an inverse thing (pointtoclient, pointtoscreen), but not this. Thanks!
Reply #3 - Apr 12th, 2011 at 11:59am
You can use the MousePosition property of your Form - it will provide the position in screen coordinates.
Let me know if this works.
Lemings
Reply #4 - Apr 12th, 2011 at 12:10pm
Thanks, works great Smiley
