Normal Topic Delete DecorationLine? (Read 2416 times)
Carlos_Rocha
I love Jazz
Apr 18th, 2011 at 5:15pm
Hi Stoyo,
DeleteItem(Item) doesn't work for DecorationLines, right?
Using Undo() is the best option?
Thank you
Re: Delete DecorationLine?
Reply #1 - Apr 18th, 2011 at 6:20pm
Hi Carlos,
You can only delete them with the Delete key at this time.
Carlos_Rocha
I love Jazz
Reply #2 - Apr 18th, 2011 at 9:23pm
I only need DecorationLines to show the user where the Table Row is allowed to be droped. After leaving each possible position I "Undo" the DecorationLine and create a new one if the new position is able to receive the dragged row. So, for this particular case the Undo() is working fine. Thanks
