Normal Topic ContainerNodes and Groups (Read 1510 times)
Novice
Apr 19th, 2011 at 4:32pm
Is it possible to create a group for nodes attachedto (and therefore displayed within and hidden when folded) a ContainerNode so that when one node is moved within the ContainerNode all the other nodes in the group are moved?
As further explanation...
Within a ContainerNode I can create a group using shapeNode1.AttachTo(shapeNode2, AttachToNode.BottomCenter) so that when one member of the group is moved by the user all members of the group are moved.
Alternatively I can create a group using containerNode.Add(shapeNode) so that when the ContainerNode is folded the DiagramNodes contained within the ContainerNode are collapsed.
But is it possible to have ShapeNodes AttachedTo a ContainerNode move in a group within the ContainerNode?
Hope my question makes sense - if not please let me know and I'll give more information.
Many Thanks
Re: ContainerNodes and Groups
Reply #1 - Apr 19th, 2011 at 4:50pm
Check if setting FollowMasterContainment on the shapeNode2's SubordinateGroup does what you need. Such groups hide when their master node is inside a folded container.
Novice
Reply #2 - Apr 19th, 2011 at 5:02pm
That's got it working.  Thanks.
