Normal Topic Creating a line and attaching it to a group? (Read 2103 times)
lenix
Apr 23rd, 2011 at 7:03am
In my diagrams I need to draw a line from a Origin point (x,y) to destination point (x,y).
I tried to do something like this:
Shape lineShape = new Shape(new ElementTemplate[]
		   new LineTemplate(originX, originY, destX, destY)
		   FillMode.Winding, "test");
		ShapeNode lineNode = new ShapeNode(diagram);
		RectangleF rect = new RectangleF(originX, originY, 10, 10);
		lineNode.Bounds = rect;
That creates a line but doesn't draw it exactly where I want it, because apparently the 2 points I set are used for the node and not the line itself.
I tried to use Factory.CreateDiagramLink with the (PointF origin,PointF dest) parameters, it works fine, but the problem is that I can't attach it to a group ( which I have to do ).
group.AttachToCorner(diagramLink, 2)
Basically I need to create a line using PointF origin, PointF destination and be able to attach it to a group that already exists.
Is that possible?
Thanks and sorry for the long thread
Re: Creating a line and attaching it to a group?
Reply #1 - Apr 25th, 2011 at 7:43am
You cannot attach links to groups. If you need that line drawn over a node, set node.CustomDraw = Additional and handle the DrawNode event by calling e.Graphics.DrawLine.
If you have version 5.6.2 of the control, you could use the new 'formula shapes' to define the line as part of a Shape at fixed points by setting DecorationsFormula to "MoveTo(originX, originY); LineTo(destX, destY);"
lenix
Reply #2 - Apr 25th, 2011 at 9:06am
Option one won't work because I need to reposition the nodes after I draw the lines.
I'm going to try option two although I'm currently using 5.6.1.
Do I just delete my current references from my project and add the 5.6.2 ones?
edit: Where can I download 5.6.2 from?
Reply #3 - Apr 25th, 2011 at 9:40am
The line will move with the nodes in both cases, isn't that what you need? You can download the latest version from https://www.mindfusion.eu/FCNetDemo.zip.
