Normal Topic about SelectedItemHandlesStyle (Read 1510 times)
paradisex
Apr 27th, 2011 at 1:57am
I'm going to change the style of SelectionHandle(default one is too big), but when I changed the diagram.SelectedItemHandlesStyle property on initilizing, it seems nothing happen.
Looking forward to your kindly advice. a simple sample will be better.  Thanks in adv!
Re: about SelectedItemHandlesStyle
Reply #1 - Apr 27th, 2011 at 5:28am
You should set Diagram.AdjustmentHandlesSize to change the handles size. In addition to SelectedItemHandlesStyle, also check the ActiveItemHandlesStyle property if you need to change something else from the handles appearance.
« Last Edit: Apr 27th, 2011 at 6:45am by Stoyo »
