Normal Topic Problems, need some help (Read 2114 times)
PDM.
Senior Member
May 2nd, 2011 at 8:32am
Hello, i continue working with my project and found new probelms
After put my form inside a scrollviewer, when node is SELECTED, some things not work more, like control + c   for copy, control + v, for paste, and delete key not delete.
Why this happen?
Other problem is no i can move node selected with arrow keys:
   form.CommandBindings.Add(new CommandBinding(Diagram.NavigateLeft, (sender, args) =>
               DiagramNode node = form.ActiveItem as DiagramNode;
               if (node != null)
                   foreach (DiagramNode SelectedNode in form.Selection.Nodes)
                   SelectedNode.Move(SelectedNode.Bounds.X - 1, SelectedNode.Bounds.Y);
How fix this?
Version used is 2.5.2 beta
Best regards
Re: Problems, need some help
Reply #1 - May 2nd, 2011 at 9:28am
Set <ScrollViewer Focusable="False" ... >, otherwise the ScrollViewer gets the keyboard focus when you click anywhere in the diagram.
PDM.
Senior Member
Reply #2 - May 2nd, 2011 at 10:08am
Thankyou!
One more question, when plan release version 2.5.2 ?
Reply #3 - May 2nd, 2011 at 10:09am
We are releasing it tomorrow.
