Normal Topic Moveing child nodes automatically (Read 3340 times)
rajesh_patil74
May 6th, 2011 at 1:05pm
Hi Stoyo
I have a container node which contains child nodes.
When I move the container node, its child elements should be moved relative.
Which property i need to set so that movement will take place automatically.
-Rajesh
Re: Moveing child nodes automatically
Reply #1 - May 6th, 2011 at 2:00pm
Hi Rajesh,
Does the container's Children collection contain anything?
rajesh_patil74
Reply #2 - May 13th, 2011 at 7:56am
Hi Stoyo
I mailed you a sample application on your and support email address.
Will you please provide me solution for the issue.
-Rajesh
Reply #3 - May 13th, 2011 at 9:24am
It seems this happens because the KeepInsideParent constraint refuses to move the child node if it is larger and outside the container. I am not sure what happens in IControlerContainerNode.MeasureOverride, but you can notice with a naked eye that the lane node is a couple of pixels larger than the pool node. So either disable KeepInsideParent or make sure the lane fits within the pool. Not related to the problem, but you should not move nodes from within MeasureOverride; do that from ArrangeOverride instead.
rajesh_patil74
Reply #4 - May 13th, 2011 at 9:44am
Thanks Stoyo
Its working properly, after changing the measureoverride to ArrangeOverride.
-Rajesh
