Normal Topic Disabling multi-select in time table (Read 2478 times)
john6630
May 13th, 2011 at 4:35am
I want to prevent the user from ctrl-click to select multiple appointments in a timetable view. I tried setting the Selection/Allow Multiple to disabled but I can still ctrl-click to select multiple items.
John
Re: Disabling multi-select in time table
Reply #1 - May 13th, 2011 at 5:55am
Selection.AllowMultiple only affects the selection of cells, not items. In order to control item selection you need to handle the Calendar.ItemSelecting event and for example set Confirm to false if Calendar.ItemSelection already contains items, or clear Calendar.ItemSelection so that only the new item remains selected.
Let me know if this helps.
john6630
Reply #2 - May 13th, 2011 at 1:55pm
Works great. Thanks.
John
