Normal Topic Composite node - Some Questions ... (Read 4281 times)
moelski
May 15th, 2011 at 6:40pm
Hi !
At the moment we are testing with the table nodes. But to create more powerful and customized nodes we want to switch to composite nodes (as you suggest us).
So here are some questions about that:
1) Is there a way to place an AnchorPoint within a GridPanel and not with absolute positions?
2) Is it possible to enrich a composite node after its creation?
We need several Output AnchorPoints at a composite node. In some cases we need to increase or decrease the number of AnchorPoints for a node. Is this possible?
Greetings
    Dominik
Re: Composite node - Some Questions ...
Reply #1 - May 16th, 2011 at 6:51am
1) You will have to inherit from ConnectionPoint and override its GetAnchor and GetAnchorPos methods to implement link alignment to anchor points. Then override CompositeNode.CreateConnectionPoint to return an instance of the connection class, and DrawAnchors to draw the anchor points where you want them relatively to the grid.
2) You could either add the points dynamically to the AnchorPattern object, or implement a different AnchorPattern for each cell in your grid (similar to TableNodes' rows) and have the custom ConnectionPoint class detect which one to use.
Another possibility is to directly set the links' first and last points in ControlPoints in response to some events instead of relying on AnchorPoints.
moelski
Reply #2 - May 16th, 2011 at 8:16am
Hi Stoyan,
That´s a good point for starting. And I think it´s easier to implement.
Actually I´m using this code to create my testnodes:
	  static public CompositeNode EntityCompCreate(Diagram diagram, ImageList images, string EntityName)
		string content = @"
	<SimplePanel>
	  <Shape Name=""Shape"" Shape=""Rectangle"" />
	    <Border Padding=""2"">
		<GridPanel>
		    <GridPanel.Rows>
			<GridRow Height=""5"" />
		    </GridPanel.Rows>
		    <GridPanel.Columns>
			  <GridColumn Width=""10"" />
			<GridColumn Width=""Auto"" />
		    </GridPanel.Columns>
<Border Name=""myBorder"" Padding=""1"" Background=""#808000"">
		    <Text Text=""Hello world!"" TextColor=""Green""  GridColumn=""1""/>
 </Border>
		</GridPanel>
	  </Border>
	</SimplePanel>";
		CompositeNode node = new CompositeNode(diagram);
		node.Bounds = new RectangleF(10, 10, 60, 10);
		node.Components.Add(XmlLoader.Load(content));
		node.Brush = new LinearGradientBrush(Color.RoyalBlue, Color.LightSkyBlue, 45);
		diagram.Nodes.Add(node);
		return node;
If I create two of these nodes in my diagram.
But I´m not able to wire them with the mouse.
So what must I do in order to do this with the mouse:
diagram1.Factory.CreateDiagramLink(node1, node2)
Greetz Dominik
Reply #3 - May 16th, 2011 at 10:13am
I was able to draw links between such nodes with all settings at their default values. Check if you are not stopping the draw operation from LinkCreating handler, or if you haven't set AllowUnanchoredLinks to false.
moelski
Reply #4 - May 17th, 2011 at 12:46pm
Hi !
That was the trick ...
Can you give me a short hint for designing the GridPanel? I need something like this:
|HEADER|
|T|GR|T|
Header is a Text, T is a small Text ("In", "Out") and GR is a small Graphic.
But actually I´m a little bit confused how to use the Gridpanel - especially how to design the columns and rows.
I tried this for the |T|GR|T| Part but that would show nothing:
		string content = @"
	<SimplePanel  Width=""30"" Height=""30"">
		<StackPanel Orientation=""Horizontal"">
		  <Text Name=""IN"" Font=""Arial, 8pt, style=Bold"" TextAlignment=""Near"" />
		  <Text Name=""FullName"" TextColor=""Blue"" TextAlignment=""Near"" />
		  <Text Name=""OUT"" Font=""Arial, 8pt"" TextAlignment=""Near"" />
		</StackPanel>
	</SimplePanel>";
Reply #5 - May 17th, 2011 at 2:45pm
Here is the code which will help you achieve your goal:
<SimplePanel>
      <Border Background=""LightSteelBlue"" Pen=""DarkBlue"" />
      <GridPanel>
            <GridPanel.Columns>
                  <GridColumn />
            <GridPanel.Rows>
                  <GridRow />
                  <GridRow />
            </GridPanel.Rows>
            <Text Text=""Header"" TextAlignment=""Center"" />
            <GridPanel GridRow=""1"">
                  <GridPanel.Columns>
                        <GridColumn />
                  <GridPanel.Rows>
                        <GridRow />
                  </GridPanel.Rows>
                  <Text Text=""In"" TextAlignment=""Near"" />
                  <Image ImageAlign=""Fit"" GridColumn=""1"" IsHitTestVisible=""False"">
                        <Image.Image>
                              <Bitmap>D:\Media\Images\Movies\Avatar.jpg</Bitmap>
                        </Image.Image>
                  </Image>
                  <Text Text=""Out"" TextAlignment=""Far"" GridColumn=""2"" />
            </GridPanel>
      </GridPanel>
</SimplePanel>
Several notes:
  • Our Grid panel does not support cell spanning therefore the sample uses two embedded grid panels.
  • The image of the Image component is a bit tedious to set in XML (as can be observed above). As an alternative you can name the Image component and set its image in code. To obtain a reference to a component given its name, use the FindComponent method of the CompositeNode class.
  • The Image component is hit-test-able by default (and will consume all mouse clicks), therefore this is explicitly turned off.
  • If you want to add a margin around the content, wrap the parent Grid panel in a Border component and set the Padding of this border to the desired value.
  • It is usually not recommended to explicitly set the Width or Height of the root component unless this is intended. If you omit the width and height, the component will try to resize itself to fit its containing node.
Let me know if this helps.
