Normal Topic Custom handle, resize problem ! (Read 5707 times)
PDM.
Senior Member
May 20th, 2011 at 11:45am
I working with custom nodes, and custom handles.
var TopLeft = new Point(0, 0);
          e.Graphics.DrawRectangle(form.SelectedItemHandlesStyle.PatternBrush, form.SelectedItemHandlesStyle.DashPen, new Rect(TopLeft, size));
The foudn a problem with custom handles.
When i rotate node, cant resize.
If i use some default handles provided work ok, but with custom handles no.
Why this happen?
Have some workaround fro fix this?
Best regards.
Re: Custom handle, resize problem !
Reply #1 - May 20th, 2011 at 1:40pm
What does your HitTestAdjustmentHandles handler look like?
PDM.
Senior Member
Reply #2 - May 21st, 2011 at 9:43am
private void form_HitTestAdjustmentHandles(object sender, HitTestEventArgs e)
      var node = e.Item as DiagramNode;
      var size = new Size(
          form.AdjustmentHandlesSize,
          form.AdjustmentHandlesSize);
      Rect r = e.Item.GetBounds();
      if (r.Contains(e.MousePosition))
          e.HitResult = 8;
      if (node != null)
          var location = node.Bounds.Location;
          var diagOffset = new Vector(location.X, location.Y);
          var TopLeftRect = new Rect(TopLeft, size);
          if (TopLeftRect.Contains(e.MousePosition - diagOffset))
              e.HitResult = 0;
          var TopMiddle = new Point(node.Bounds.Width / 2 - size.Width / 2, 0);
          var TopMiddleRect = new Rect(TopMiddle, size);
          if (TopMiddleRect.Contains(e.MousePosition - diagOffset))
              e.HitResult = 4;
          var TopRight = new Point(node.Bounds.Width - size.Width, 0);
          var TopRightRect = new Rect(TopRight, size);
          if (TopRightRect.Contains(e.MousePosition - diagOffset))
              e.HitResult = 1;
          var MiddleLeft = new Point(0, node.Bounds.Height / 2 - size.Height / 2);
          var MiddleLeftRect = new Rect(MiddleLeft, size);
          if (MiddleLeftRect.Contains(e.MousePosition - diagOffset))
              e.HitResult = 7;
          var MiddleRight = new Point(node.Bounds.Width - size.Width, node.Bounds.Height / 2 - size.Height / 2);
          var MiddleRightRect = new Rect(MiddleRight, size);
          if (MiddleRightRect.Contains(e.MousePosition - diagOffset))
              e.HitResult = 5;
          var bottomLeft = new Point(0, node.Bounds.Height - size.Height);
          var bottomLeftRect = new Rect(bottomLeft, size);
          if (bottomLeftRect.Contains(e.MousePosition - diagOffset))
              e.HitResult = 3;
          var bottomMiddle = new Point(node.Bounds.Width / 2 - size.Width / 2, node.Bounds.Height - size.Height);
          var bottomMiddleRect = new Rect(bottomMiddle, size);
          if (bottomMiddleRect.Contains(e.MousePosition - diagOffset))
              e.HitResult = 6;
          var bottomRight = new Point(node.Bounds.Width - size.Width, node.Bounds.Height - size.Height);
          var bottomRightRect = new Rect(bottomRight, size);
          if (bottomRightRect.Contains(e.MousePosition - diagOffset))
              e.HitResult = 2;
void form_DrawAdjustmentHandles(object sender, DrawItemEventArgs e)
var size = new Size(form.AdjustmentHandlesSize,form.AdjustmentHandlesSize);
if (node != null)
          e.Graphics.DrawRectangle(form.SelectedItemHandlesStyle.PatternBrush, form.SelectedItemHandlesStyle.DashPen, new Rect(TopMiddle, size));
          var TopRight = new Point(node.Bounds.Width  - size.Width , 0);
          e.Graphics.DrawRectangle(form.SelectedItemHandlesStyle.PatternBrush, form.SelectedItemHandlesStyle.DashPen, new Rect(TopRight, size));
          var MiddleTop = new Point(0, node.Bounds.Height /2 - size.Height /2);
          e.Graphics.DrawRectangle(form.SelectedItemHandlesStyle.PatternBrush, form.SelectedItemHandlesStyle.DashPen, new Rect(MiddleTop, size));
          var MiddleBott = new Point(node.Bounds.Width - size.Width, node.Bounds.Height / 2 - size.Height / 2);
          e.Graphics.DrawRectangle(form.SelectedItemHandlesStyle.PatternBrush, form.SelectedItemHandlesStyle.DashPen, new Rect(MiddleBott, size));
          e.Graphics.DrawRectangle(form.SelectedItemHandlesStyle.PatternBrush, form.SelectedItemHandlesStyle.DashPen, new Rect(bottomLeft, size));
    var bottomMiddle = new Point(node.Bounds.Width / 2 - size.Width / 2,node.Bounds.Height - size.Height);
           e.Graphics.DrawRectangle(form.SelectedItemHandlesStyle.PatternBrush, form.SelectedItemHandlesStyle.DashPen, new Rect(bottomMiddle, size));
           var bottomRight = new Point(node.Bounds.Width  - size.Width ,node.Bounds.Height - size.Height);
           e.Graphics.DrawRectangle(form.SelectedItemHandlesStyle.PatternBrush, form.SelectedItemHandlesStyle.DashPen, new Rect(bottomRight, size));
Reply #3 - May 23rd, 2011 at 5:48am
Add this code to the front of your handler and then use localPoint when calling Rect.Contains:
double rotationAngle = node.RotationAngle;
Point localPoint = RotatePointAt(e.MousePosition, node.GetCenter(), -rotationAngle);
localPoint = localPoint - diagOffset;
Point RotatePointAt(Point point, Point pivot, double angle)
	Matrix rotation = new Matrix();
	rotation.RotateAt(angle, pivot.X, pivot.Y);
	Point res = rotation.Transform(point);
	return res;
PDM.
Senior Member
Reply #4 - May 23rd, 2011 at 1:11pm
Really sorry but not understand how this work.
Can rotate correclty what cant do is RESIZE node rotated.
M rotating my nodes in this way:
node.RotationAngle = 90;
I not understand your solution and how apply.
Please can put complete example?
Best regards.
Reply #5 - May 24th, 2011 at 6:29am
	return res;
		e.HitResult = 8;
	if (node != null)
		if (TopLeftRect.Contains(localPoint))
			e.HitResult = 0;
		if (TopMiddleRect.Contains(localPoint))
			e.HitResult = 4;
		if (TopRightRect.Contains(localPoint))
			e.HitResult = 1;
		if (MiddleLeftRect.Contains(localPoint))
			e.HitResult = 7;
		if (MiddleRightRect.Contains(localPoint))
			e.HitResult = 5;
		if (bottomLeftRect.Contains(localPoint))
			e.HitResult = 3;
		if (bottomMiddleRect.Contains(localPoint))
			e.HitResult = 6;
		if (bottomRightRect.Contains(localPoint))
			e.HitResult = 2;
PDM.
Senior Member
Reply #6 - Sep 6th, 2011 at 5:34pm
Stoyo, after roatte i can resize, but see a new problem.
Only can drag and move the object selecting form the center only.
Why this happen and how can fix this, when object is rotated is very hard move the node, can drag, only can drag form the center.
A simple example for ilustrate thsi stiaution is create a simple large vertical shape, then rotate, and try drag, you cna see can drag and move only if drag the object form the center.
If shape is perfect square, or perfect circle not have any problem to drag selecting te node form any palce and the drag andmove.
Only happen when is a large rectangle shape.
Hoppe can help to me with this.
Reply #7 - Sep 7th, 2011 at 8:21am
Hi Pablo,
Move the code that calls r.Contains so that it tests with the rotated point:
if (node != null)
	if (r.Contains(localPoint))
		e.HitResult = 8;
		return;
PDM.
Senior Member
Reply #8 - Sep 7th, 2011 at 12:17pm
Thankyiu fixed now!
Return comented.
if (node != null)
e.HitResult = 8;
//return;
