Normal Topic Containernodes losing attached nodes (Read 1118 times)
theredguy
May 26th, 2011 at 3:33am
I have just started using containernodes which looks very useful.
However, I have come across a problem. I have a container node with various shapenodes children.
When I have no links the container node has them all within the container bounds. I can also see that I have 3 attached nodes by showing SubordinateGroup.attachednodes.count. after I add some links (programatically) the shapenodes have moved out of the bounds of the container and now I have only 1 attached node.
Any suggestions how I am supposed to add links so that it does not lose the attached nodes.
Re: Containernodes losing attached nodes
Reply #1 - May 26th, 2011 at 6:02am
I can't imagine how child nodes can move out of the container if you only add links. Are you calling any other methods of the control after creating links?
