Normal Topic Checking for loops in diagram? (Read 2198 times)
nbourgogne
May 27th, 2011 at 7:56pm
Hi all,
I just downloaded the trial version of diagramlite for Silverlight, and I was wondering if there is a built-in or recommended way of checking for loops?
I want to create some sort of workflow where loops are not allowed, and I'd like to know if there's some built-in functionality before I start iterating through each node to check for a loop.
Thanks!
Re: Checking for loops in diagram?
Reply #1 - May 30th, 2011 at 6:32am
You can use the PathFinder class for this. Its FindCycle method will let you find out if a cycle already exists.
If you need to prevent users from creating cycles interactively, call PathFinder.FindShortestPath(e.Destination, e.Origin) from the LinkCreating handler, and if it finds a path set e.Cancel = true; an existing path from destination to origin means the new link would create a cycle.
nbourgogne
Reply #2 - May 30th, 2011 at 1:30pm
Cool, thanks, I'll try it out!
