Normal Topic Get DiagramLink coordinates halfway in the link (Read 1958 times)
Bass
Jun 15th, 2011 at 10:05am
I would like to programmatically create a ControlNode halfway down a diagram link, but am not sure how to approach this.
During diagram design, the user can drag and drop a ControlNode on a link, and this will split the link into two parts allowing the ControlNode to fit nicely in the middle.
Now I want to the same thing pogrammatically, when the diagram is loaded and it is determined that a ControlNode exists for a particular link.
The problem is that I want to create the ControlNode in the middle of the link. What would be a good way to get a PointF object based on the coordinates of the middle of the diagram link?
The only alternative I see would be to save the coordinates with the ControlNode back to the database.. but I would like to avoid that if possible.
Bas
Re: Get DiagramLink coordinates halfway in the lin
Reply #1 - Jun 15th, 2011 at 10:51am
Assuming a multi-segment Polyline or Cascading link, you can find the point at its exact middle using this method with 0.5 as argument:
PointF PointAlongLength(DiagramLink link, float lengthFactor)
	float lengthPos = lengthFactor * link.Length;
	float totalLength = 0;
	var segments = link.ControlPoints;
	for (int i = 0; i < segments.Count - 1; ++i)
		PointF point1 = segments[i];
		PointF point2 = segments[i + 1];
		float segmentLength = Utilities.Distance(point1, point2);
		if (totalLength + segmentLength > lengthPos)
			// the wanted point is in current segment
			float normalX = (point2.X - point1.X) / segmentLength;
			float normalY = (point2.Y - point1.Y) / segmentLength;
			float pointOffset = lengthPos - totalLength;
			return new PointF(
				point1.X + normalX * pointOffset,
				point1.Y + normalY * pointOffset);
		totalLength += segmentLength;
	return segments[0];
If you need to find that for Bezier links, you will have to approximate them through straight-line segments.
Bass
Reply #2 - Jun 15th, 2011 at 11:53am
Thanks for quick and working answer. A+ for support here.
Bas
