Normal Topic Attached Nodes (Read 2137 times)
Amosius
Attached Nodes
Jun 16th, 2011 at 10:37am
i have a mainnode with 3 attached nodes inside.
I want to display informations with the 3 attached nodes, but all mouseclicks shall be handled by the subjacent mainnode, even when i am over one of the 3 attached nodes.
Do you have a property for this?
Amosius
Re: Attached Nodes
Reply #1 - Jun 16th, 2011 at 11:05am
There's no property for this. You could call the event handler for the main node instead:
private void OnNodeClicked(object sender, NodeEventArgs e)
	if (e.Node.MasterGroup != null)
		OnNodeClicked(sender,
			new NodeEventArgs((DiagramNode)e.Node.MasterGroup.MainItem));
	// etc.
Amosius
Re: Attached Nodes
Reply #2 - Jun 16th, 2011 at 1:59pm
Hello Stoyan,
I handled with this codesnippet right clicks for context menu. I also used this in the diagram_NodeDoubleClicked(..)
event handler to edit text.
Works fine now. Thank you.
Amosius
