Normal Topic Can't move node (Read 3614 times)
lenix
Can't move node
Jun 20th, 2011 at 10:06am
After I draw my diagram I try to move some nodes around by using the mouse and the move handle.
But only 1 node in my diagram is able to move, all others return to their original positions after trying to move them.
What could prevent a node from being moved?
Note that the node is not locked because I get the handles, it just goes back to original position after moving it.
Thanks in advance
Re: Can't move node
Reply #1 - Jun 20th, 2011 at 10:21am
This could happen if you move a node outside the Diagram.Bounds rectangle. Try calling ResizeToFitItems after building the diagram, assign a large rectangle to Bounds, or set the AutoResize property.
If none of the above helps, check the NodeModifying handler; nodes will return to their original position if the handler sets e .Cancel = true.
lenix
Re: Can't move node
Reply #2 - Jun 20th, 2011 at 1:05pm
Thanks for the help.
I tried your suggestions and I wasn't lucky because the problem seems to be not related to moving outside the bounds of the diagram.
I noticed something though when I registered to the NodeModifying event.  The event gets called when I try to move the nodes that are able to move freely.
But the event doesn't get called when I try to move another node ( the ones that can't be moved ).
It's like the stuck nodes aren't really nodes.
To be more clear on the problem: The mouse cursor turns to "not allowed" when I drag drop one of the immovable nodes ( and the node actually moves until i release the mouse button, then it goes back to original position ).
Any ideas?
Re: Can't move node
Reply #3 - Jun 20th, 2011 at 1:52pm
How many nodes are there in the Diagram.Nodes collection? Is there any difference between how you are creating the moveable and immovable nodes?
Re: Can't move node
Reply #4 - Jun 20th, 2011 at 3:04pm
I now recall a similar problem happening if you programmatically create nodes smaller than Diagram.MinimumNodeSize. If the immovable nodes are very small, try either making them larger or set MinimumNodeSize to a smaller value.
lenix
Re: Can't move node
Reply #5 - Jun 21st, 2011 at 8:03am
Thanks Stoyo, it was the MinimumNodeSize.
I did diagram.MinimumNodeSize = new SizeF(1,1);
and now everything is running great.
Thanks again
