Normal Topic NodeDeleting not fired for ControlNode type (Read 1348 times)
Bass
Jun 21st, 2011 at 9:51am
Hi Stoyan,
I have an event handler defined for the Diagram.NodeDeleting event which works fine for all shape nodes I am deleting from the diagram.
However, when I remove a control node the event is not fired. As a workaround I am using Diagram.ItemRemoved with some additional type checking to get around this, but is there a better way?
Bas
Re: NodeDeleting not fired for ControlNode type
Reply #1 - Jun 21st, 2011 at 10:44am
Hello Bas,
The event is raised as expected in my test. What does your handler look like?
