Normal Topic The text of shape will be cut off on some setting (Read 2318 times)
geanyee
Jun 22nd, 2011 at 9:14am
I encountered a problem when using the diagram component on the winform.
If we set the text like "Mijangos Natalia" to one shape, and set the textformat as "Center|Far", the character of "j"  and "g" will be cut off part of bottom.
Please see the attached picture.
Is there anybody can help me to figure out the problem? Thanks in advance.
Re: The text of shape will be cut off on some sett
Reply #1 - Jun 22nd, 2011 at 10:46am
I think text is aligned relatively to the font's baseline in this case, and since by default there's no margin, the descenders might get clipped. Try setting TextPadding.Bottom = 1 to add some empty space between the text and bottom border.
geanyee
Reply #2 - Jun 23rd, 2011 at 3:59am
Hi, thanks for your reply.
But I'm not sure how to set the TextPadding property, I did not find this property on DiagramItem or Diagram, could you please figure it out?
-Yee
Reply #3 - Jun 23rd, 2011 at 4:14am
What version of the control are you using? From the release history it seems TextPadding was added in version 5.4.
geanyee
Reply #4 - Jun 23rd, 2011 at 5:17am
I'm using version 5.3.5, then we cannot find the property for sure.
I will update the version later, thanks.
