Normal Topic Print diagram flowchart (Read 5975 times)
rafael.06
Jun 28th, 2011 at 12:01pm
I´m trying Print the flowchart diagram and table of data using PrintDiagram function. To print, i´m using the ScaleToPage function to put all the diagram only one page but now, i want print the diagram on first page and the table of data on second page. Any suggestion for this task?
Re: Print diagram flowchart
Reply #1 - Jun 28th, 2011 at 12:04pm
Is that table of data displayed using a FlowchartX Table object?
rafael.06
Reply #2 - Jun 28th, 2011 at 1:06pm
I creating the table using the class BoxItem and put the data inside of box. Like this:
BoxItem boxSequence;
CString strTitle;
strTitle.Format("Equipe de investigação: ");
//Text 1 title
boxSequence = this->CreateBox(nX, nY+ i*height, width - widthDescription - widthDay - widthHour , height);
CString strSequence = "Seq";
boxSequence.SetEnableStyledText(true);
boxSequence.SetTextStyle(tsLeft);
boxSequence.SetStyle(bsShape);
boxSequence.SetTextColor(RGB(0,0,0));
boxSequence.SetFillColor(RGB(214,214,214));
boxSequence.SetText( strSequence );
This code is a part of table that i put in the flowchart view...
Reply #3 - Jun 28th, 2011 at 1:15pm
If you call ScaleToPage before creating the data box, it should appear on the next page, as long as it is below all other flowchart items.
rafael.06
Reply #4 - Jun 28th, 2011 at 1:43pm
Thanks a lot!
This solution works well...
rafael.06
Reply #5 - Jul 7th, 2011 at 7:59pm
I need create a pdf report with flowchart diagram and others informations. The report was created with success but new questions appeared.
Q1: How can i put a specific text into one page? i.e: I want control the information in each page and avoid text cut off between pages.
Q2: How can i print report with vetorial image? I´m generating all the datas of report in the flowchart view and printing the report with PrintDiagram function. When the print is finished, i redraw the window and keep only flowchart diagram. The pdf report doesn´t have a good quality...
Thanks!
Reply #6 - Jul 7th, 2011 at 8:46pm
Are you using some kind of PDF virtual printer?
rafael.06
Reply #7 - Jul 7th, 2011 at 9:39pm
i´m using CutePDF writer
Reply #8 - Jul 8th, 2011 at 6:18am
1. You could enable ShowPageMarkers and let your users draw text boxes away from the marker lines. If you need to do that automatically, you will have to query the printer driver for the default page size and shift boxes up or down to avoid the page boundaries.
2. What makes you think it's not a vector image? FlowchartX prints using standard drawing APIs that should result in corresponding PDF vector drawing elements. I have tried printing with the latest CutePDF and the generated PDFs look fine.
