Normal Topic Is there TextNode ? (Read 1108 times)
CanadaProgrammer
Is there TextNode ?
Jul 5th, 2011 at 6:58am
I want to put a shape to allow user input text. I tried to use ControlNode (Control type is RichText)but it is not good enough. When I changed the size of ContorlNode it is really ugly. Is there any good way to reach my goal?
Re: Is there TextNode ?
Reply #1 - Jul 5th, 2011 at 7:06am
The user can enter text by double-clicking a ShapeNode when AllowInplaceEdit is enabled. You might also call DiagramView.BeginEdit from the NodeClicked handler to start editing with a single click.
If you handle the CreateEditControl event, you will be able to replace the standard textbox used for editing with your own control. This is shown in the InteractiveTable sample project.
